The first image is a screen shot of an active FreeCAD where visually it's hard to tell sketch lines (white ones) laid on top of blue construction lines. The second image is created through FreeCADs "Save Picture" located under Tools. What setting can I change to show sketch lines on the top layer and blue construction on the bottom or back layer? May be this is a bug!!!
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10807 (Git)
Build type: None
Hash: b32e9806e1b075c745c0c9692e81aea1dcab81e4
Python version: 2.7.12
OCC version: 7.1.0
0.17 sketch lines turn blue when on top of construction lines.
Re: 0.17 sketch lines turn blue when on top of construction lines.
This has long been an issue, and it's why I recommend to try very hard not to overlap regular geometry on top of construction geometry. Most of the time I find it's unneeded.
Besides I don't understand the purpose of having a "regular" circle on top of a construction circle...
As far as I know it's not possible.rjpeek wrote:What setting can I change to show sketch lines on the top layer and blue construction on the bottom or back layer?
The way that I've been using Sketcher is to layout geometry of an object that I'm trying to re-engineer. After I know the geometry then I can CAD it in FreeCAD. Ideally I wish there was a tool similar to Sketcher with many of the same bells and whistles (constraints, dimensions, etc...) that would produce a flat drawing (2D) that could easily be printed out in black and white. As an example I have three physical radio control car parts, left and right gear casings and a thin metal plate that's positioned between them. Some of the geometry is the same like the outside edge while the inside guts are different. Some times to get geometry on the right casing I have to refer to the left casing or the metal plate. I've tried Draft but don't find it useful or I'm not understanding how to use it in this situation.
