hI again
1) the origin of the sketch is left under, from this point I had the dimensions of 4 mm Horizontal and 4 mm Vertical
2) The blue rectangle is a construction rectangle, it defines the center of the holes, it is also possible to dimension all the holes individual, but using this helping aid is easier. You change to construction mode with this icon
3) Study this chapter https://www.freecadweb.org/wiki/Sketcher_Workbench
4) I do not understand this question, give an example
I did not copy anything I just made a new sketch with the dimensions from the existing design
I forgot to make the fillet
How can I trim/resize a Printed Circuit Board support post?
Re: How can I trim/resize a Printed Circuit Board support post?
Hello Rudolf,
From the PartDesign Workbench documentation page:rudi48 wrote:It is interesting to see, that for the *.STL file export you just need to mark the last object (Pad011).
the wiki wrote:As we create a model in the Part Design Workbench, each feature takes the shape of the last one and adds or removes something, creating linear dependencies from feature to feature as the model is created. Hence a "Cut" feature is not only the cut hole itself, but the whole part with the cut.
Hello NormandC,
Thank you very much for entighting the situation.
With each step, I learn more to use FreeCAD the intended way, which is not so easy for a beginner.
Youtube Videos are nice, but you have to understand also the philosophy behind.
Therefore I appreciate very much the help of the forum members.
Regards, Rudolf
Regards, Rudolf
Hi Rudolf,
Glad to help. It's true that most Youtube tutorials are task-based (do this then do that), and most of them don't explain why it works that way.
