Hello to all,
I'm having some troubles trying to 3d print this design - > https://we.tl/g9WYaXviCs (I dont know how to attatch it here because of it's size)
when I analize it always says non manifold object, I can see the non manifold on the 3d print program but I can't see it on freecad. The objects who have non manifold faces are the 'Dani' Word and the shisha icon, the Dani Word is non manifold only when I cut it, but before not. The shisha icon always is manifold. Both are Designs imported in svg with illustrator and extruded them.
I made the svg process before and it worked, I don't know where is the problem, maybe some experts here?
Thank you all!
Non manifold faces on stl
Re: Non manifold faces on stl
I don't have problems exporting to STL and importing into my 3D-slicer.
It sounds as if you selected more than one object for export. You should select only the last object in the tree, in your case Fusion002.
That's what I made, I will try uninstalling and installing the latest versión, maybe it's the problem. Thank you!chrisb wrote:I don't have problems exporting to STL and importing into my 3D-slicer.
