Linking issue issue #3002 to this thread
OS: Linux
Version: 0.17.10807 (Git)
Build type: Unknown
Hash: b32e9806e1b075c745c0c9692e81aea1dcab81e4
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
Hi all,
In the Arch workbench, drawing closed polyline shapes in the standard XY plane, then clicking the Arch Structure button, selected shapes are extruded in different directions. So, is there a way to control the Z axis extrusion direction within the GUI?
Regards,
-- fb
Unable to control extrusion direction for Arch Structure object(s)
Re: Unable to control extrusion direction for Arch Structure object(s)
Hi, I think you dit not change the woking plane from AUTO to TOP
@Willem: thank you for your answer. A quick test after selecting the working plane from Auto to Top doesn't solve the problem. I'm still unable to predict and control the Arch Structure Z axis extrusion direction.
-- fb
-- fb
Use the Normal property of the arch object. If you leave it to (0,0,0), the extrusion direction is automatic and can indeed be wrong sometimes. But you can manually set it to, for example, (0,0,1)
