Crash FreeCAD: Draft WB > Draft Edit tool
hedgehog
Postby hedgehog » Sat Apr 15, 2017 11:55 pm
This bug has now been fixed.
Best Wishes
Hedgehog
OS: Ubuntu 16.04.2 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
20150529a-GoldenRectangle.fcstd
(7.49 KiB) Downloaded 2 times
NormandC
Re: Crash FreeCAD: Draft WB > Draft Edit tool
Postby NormandC » Sun Apr 16, 2017 2:55 am
It would help if you described here the issue so viewing the screencast wasn't necessary.
Granted it shouldn't crash, but how did you even think of trying to use Draft Edit on a Sketch? Draft and Sketcher are two completely different workbenches, you cannot simply use one's tool in the other workbench.
hedgehog
Postby hedgehog » Sun Apr 16, 2017 4:44 am
Hi NormanC, Thanks for looking at this.
NormandC wrote:It would help if you described here the issue so viewing the screencast wasn't necessary.
In my experience a creencast is far more efficient and most importantly definitive. That is, it answers the question: What "exactly" did you do before the crash, e.g. moving the toolbars etc. Hopefully someone can reproduce the crash just with the Draft edit tool? But if not, they can see "everything" that was done.
NormandC wrote:Granted it shouldn't crash, but how did you even think of trying to use Draft Edit on a Sketch?
By two errors of mine it seems:
The first error is misunderstanding you here: https://forum.freecadweb.org/viewtopic. ... 86#p145672
My apologies.
NormandC wrote:Draft and Sketcher are two completely different workbenches, you cannot simply use one's tool in the other workbench.
My understanding is that I regularly apply another workbench tool to a sketch. For example, padding the sketch. I it seemed to me that I was doing to the sketch what I regularly do, apply another workbench tool. Just this time it was not a part/part design tool.
So the second error is, misunderstanding the FreeCAD UI principles. Generally it seems that when a tool cannot be used it is disabled/inactive.
If nothing else I was able to learn that today.
But you are correct. It should not crash.
Best wishes
Hedgehog
NormandC
Postby NormandC » Sun Apr 16, 2017 4:56 am
The problem is that nowhere in your topic subject or content do you mention what the bug is really about. People would logically assume that the Draft Edit tool crashes when editing Draft objects, which is not the issue here. If I didn't write about it, nobody would know without looking at your screencast... and this is just wrong. The first thing I did was to open your attached file and see only a Sketch in it, while I was expecting Draft objects - and this had me puzzled.
All the pertinent info should be detailed here without requiring to look at an external screencast you plan on deleting.
Cheers
Norm
yorik
Site Admin
Postby yorik » Sun Apr 16, 2017 3:19 pm
The crash is now solved in git commit 3b06b8616
NormandC
Postby NormandC » Sun Apr 16, 2017 3:21 pm
That was quick :D
yorik
Site Admin
Postby yorik » Mon Apr 17, 2017 3:24 pm
NormandC wrote:That was quick :D
Mostly because it was easy to solve :?
hedgehog
Postby hedgehog » Wed Apr 19, 2017 9:00 pm
NormandC wrote:The problem is that nowhere in your topic subject or content do you mention what the bug is really about.
Apologies. I honestly thought "Crash FreeCAD:" was explicit about what crashed.
NormandC wrote:People would logically assume that the Draft Edit tool crashes when editing Draft objects, which is not the issue here.
Which is why I titled the subject "Crash FreeCAD:" and not "Crash Draft Edit tool:".
On reflection my use of a colon presumed an understanding that, in technical contexts, it is used to *precede* an expansion or explanation. This understanding might be English specific and I probably shouldn't have used that shorthand.
Apologies if that caused anyone to go down a rabbit hole or shave a Yak.
NormandC wrote:If I didn't write about it, nobody would know without looking at your screencast... and this is just wrong.
Point taken.
NormandC wrote:The first thing I did was to open your attached file and see only a Sketch in it, while I was expecting Draft objects - and this had me puzzled.
Again apologies for any misdirection or time wasted.
NormandC wrote:All the pertinent info should be detailed here without requiring to look at an external screencast you plan on deleting.
Point taken.
hedgehog
Postby hedgehog » Wed Apr 19, 2017 9:44 pm
Thanks for your efforts Yorik.
Best wishes
Hedgehog
