How to modify heights of model created by a sketch in the X-Y pane?
adi.barda
Post by adi.barda »
I have created a simple sketch with some constraints on the X-Y pane and then pad it.
Now that I have a 3D model out of my sketch, I would like to put some more constraints so that the rear and front heights of the model will not be the same size (see attachment)
The model after padding the sketch
And, here is the sketch that was padded:
The sketch that was padded
It's a beginner question but I spent a lot of hours before submitting that question :)
Thanks you,
Adi Barda
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
bejant
Re: How to modify heights of model created by a sketch in the X-Y pane?
Post by bejant »
Hi Adi and welcome! Select one of the 20 mm faces, click the Create Sketch tool, and Sketcher a triangle. Use the Link To External Geometry tool to create edges from Pad so you can constrain vertices of the triangle onto them:
Then Pocket "Through All"
20170417a-016-adi.barda.fcstd
(17.54 KiB) Downloaded 15 times
OS: Ubuntu 16.04.2 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6707 (Git)
Build type: None
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
