When I attempted a loft between Front Brim Left Facebinder object and Back Brim Left Facebinder object it produced the following error:
Here is the FreeCAD file:
Is this a bug in FreeCAD or am I doing something wrong?
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
The same error occurred when I exploded the Front Brim and Back Brim sweep objects and attempted to loft the Face objects directly.Attempting Loft between two Facebinder objects produces Input Error
Re: Attempting Loft between two Facebinder objects produces Input Error
At least you get an error. On Linux, it makes FreeCAD 0.16.6707 crash.Jacutus wrote:When I attempted a loft between Front Brim Left Facebinder object and Back Brim Left Facebinder object it produced the following error:
In the current 0.17-dev build based on OCC 7.1.0, I get the following error which gives at least some info:
Part Loft wrote:BRepFill :: profiles are inconsistent
It's a limitation rather than a bug, and yes, you are doing something wrong, or at least you are making it difficult to the software.Jacutus wrote:Is this a bug in FreeCAD or am I doing something wrong?
When doing lofts, it's always best for all the profiles to have the same number of line/arc segments. That way, points on each profile are connected with a defined edge on the loft. Otherwise, the OCC geometric kernel has to interpolate, and it's not always able to do so.
Back of Brim Sketch has 10 elements, while Front of Brim Sketch has 8. Try to divide your sketch to add two more lines, ideally more or less aligned to the ones on the other sketch. Then the loft might succeed.
