jidoeuf wrote:Beware of FreeCAD version used !
Between 0.16 and 0.17, the following features behave differently:
- Part Join Connect,
- Export to IGES, STEP, ...
@easyw-fc, I think you use 0.17 ?
@daveconventry, I think you use 0.16 ?
yes thx @jidoeuf, I forgot to tell Dave I'm using FC0.17... in FC0.17 you can connect multiple objects...
... stil some weird things may happen when using connect feature... for example with this part everything is fine:
as1-oc-214.stp
the 'connect' operation is fine and the STEP exported has only external geometries in FC017
- fc017-connected.PNG (286.37 KiB) Viewed 1224 times
but with this one:
something wrong happens:
- fc017-connected-weird.PNG (252.83 KiB) Viewed 1224 times
Probably a bug in FC017 I think or something related to OCC weirdness ...
Maurice
PS to Dave:
NB if you are going to use FC0.17 for testing these features, DO NOT save your original work (probably made in FC0.16) but work only on a copy
