[SOLVED} Pocket Errors
I'm having trouble with making a pocket. I got the base and first inset pocket done but I want to add 4 holes for bolts so we can mount a bracket to it. Every time I try to make the pocket using the sketch named Bolt Mount or Sketch007 I get an error that there are no valid sketches. I've deleted and redrawn the sketch thinking it was a bug or something but somewhere I've missed a step... Can someone tell me where I went wrong?
- Lower Kisok Mount.FCStd
- (10.24 KiB) Downloaded 21 times
Re: Pocket Errors
Hi RogueWatchmen, and welcome!
Change the circles in the sketch named Bolt Mount from blue to white using the Sketcher Toggle Mode Tool:
and try again.
Delete Sketch007; you Forked your model by creating it. We can see that by using Tools > Dependency Graph:
http://www.freecadweb.org/wiki/Std_DependencyGraph
which you have to install before it can be used.
and try again.
Re: [SOLVED} Pocket Errors
Thanks, worked like a charm.
