Check Geometry shows error in Sweep
Jacutus
Post by Jacutus »
Check Geometry shows that the Sweep is solid but invalid and Shell1 is not connected.
Shape Content shows:
VFP_Proto_Helmut_with_Front_and_Back_Brims.Sweep:
VERTEX : 400
EDGE : 610
WIRE : 212
FACE : 212
SHELL : 1
SOLID : 1
COMPSOLID : 0
COMPOUND : 0
SHAPE : 1436
Anyone have any idea what I'm doing wrong here and what I do to correct it?
VFP Proto-Helmut Single Brim Sweep.jpg (318.47 KiB) Viewed 984 times
https://www.dropbox.com/s/sylelwnua4krk ... FCStd?dl=0
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
renatorivo
Re: Check Geometry shows error in Sweep
Post by renatorivo »
It's not exactly what you want, but it's an idea
VFP-Renato.FCStd
(488.42 KiB) Downloaded 17 times
Renato
Jacutus
Post by Jacutus »
Thank you! Could you give me step by step instructions on how you did that? It looks better than what I have.
renatorivo
Jacutus wrote:Could you give me step by step instructions on how you did that?
I'm trying
1 - Import useful items (ImagePlane, HollowSphere001, Front of Brim Sketch)
2 - Since your cut object is made up of many edges, and after it requires a fusion with a cube, I changed its profile and its position just below the top line of Front of Brim, this to intersect the results
3 - Pad001 and Cut004 are the next operations
4 - Simplified Front of Brim Sketch, but you can do better...
5 - Sweep004 along the outer contour with Frenet = False, this allows the faces to follow the contour orientation
6 - Check Sweep004 and Cut004
7 - Fusion001 -> Check -> Valid
Sweep between two Sketches requires the same number of points between the initial and the final figure, otherwise the result is unpredictable.
Sweep along a segmented path tends to self-intersect and is not valid. It generates a bunch of lines and creates very large files.
VFP Proto 1,33 MB
VFP_Proto_Helmut_with_Brim_Sweep.Sweep:
VERTEX : 400
EDGE : 610
WIRE : 212
FACE : 212
SHELL : 1
SOLID : 1
COMPSOLID : 0
COMPOUND : 0
SHAPE : 1436
VFP-Renato 488 KB
VFP_Renato.Sweep004:
VERTEX : 32
EDGE : 56
WIRE : 26
FACE : 26
SHELL : 1
SOLID : 1
COMPSOLID : 0
COMPOUND : 0
SHAPE : 142
Renato
