OS: Mac OS X
Version: 0.16.6706 (Git)
Branch: tag: 0.16.6706
Python version: 2.7.11
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
I am trying to put a hole in this bracket, and I'm worried I may have made a mistake. I was able to sketch the hole I need on the bracket but I can't figure out how to get an extrusion and then subtract to make a hole. Forgive me for I am new to this program. I need the extrusion to be squared up to that plane, but as you can see in the picture it will only go in the X Y or Z direction, whereas I need it to go somewhere in between.
I am assuming maybe there is a way to change the normal direction of the plane? When I extrude, I haven't been able to figure out a way to have it be perpendicular to the sketches plane.
Trouble extruding on an angled plane
- Screen Shot 2017-04-20 at 5.53.29 PM.png (15.42 KiB) Viewed 662 times
- Screen Shot 2017-04-20 at 5.51.51 PM.png (25.96 KiB) Viewed 662 times
- microelly2
Re: Trouble extruding on an angled plane
Welcome to the forum
If you want something like this
you dryw the sketches onto the faces and create pockets I have at the moment only 0.17 installed, here is my demo file.
- pockets.fcstd
- (36.66 KiB) Downloaded 25 times
I'm not having any luck with the pockets... It doesn't show up. Maybe I am screwing something up with how the faces were made? I drew the profile of the bracket and then extruded it. Not sure if that matters. I am able to make a pad in the Part Design workbench, but when I try to make one and then subtract it to get the hole, I have no luck...
- microelly2
See the videoboxman555 wrote:I am able to make a pad in the Part Design workbench, but when I try to make one and then subtract it to get the hole, I have no luck...
you make first your base shape (for fast I do a pad),
then the sketch and a pocket
https://youtu.be/NPJbBechpPk
Got it, ok thank you so much! I'm still trying to get comfortable with the software so I appreciate it!!!
