Assembly: How to offset axial constraints?
sjgallagher2
Post by sjgallagher2 »
Hello all.
I'm trying to offset two cylinders at a fixed radius from one-another, without an enclosing surface.
For example, if you had shafts that were supposed to be 8 inches apart, from center to center, in an assembly. Or if you wanted to set the distance between gear centers and have it be variable so if you changed a gear you could alter the assembly by simply changing the distance between gear axes.
Currently, I am making an enclosure with two circular cutouts at the right distance apart, but as the number of aligned shafts increases and as I make more changes, it's getting quite frustrating.
Is there a better way to offset shaft axes in FreeCAD?
OS: Linux Mint 18 Sarah
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Thanks,
Sam
Re: Assembly: How to offset axial constraints?
You can use expressions or - if you have lots of them - a spreadsheet to control the positions.
And here is my daily reminder: Be aware that the Placement dialog cannot handle expressions, use them in the data tab instead.
