how to draw a pair of glasses
jpg87
Post by jpg87 »
I challenged myself to draw this pair of glasses proposed in the French forum (Postby kryscosne » Thu Jan 26, 2017 3:22 pm) :
I followed the advice of NormandC to obtain profile corresponding to the curvature and curve of the glass (steps 1 and 2) :
I then drew an outline for the section of the frame. Until then, everything seems correct (steps 3 and 4).
I tried several options for scanning (contour closed or not, different types of calculation, ...), then from an open outline which seemed to me the best solution, I created a slot a bit more wide to clean the ends of the shape (step 5).
I then created the two tabs for the glass pinch screw (steps 6 and 7).
Then when I wanted to create the side branch support of the mount, that's what I get (step 8).
I tried to make different body parts, but impossible to merge them!
PS: Can not attach file: more than 30 MB !!!!
My configuration :
Version: 0.17.10885 (Git)
Hash: ad112ca8ab7fa0b9524dfa682f6b82048345c0ef
Python version: 2.7.8
OCC version: 7.0.0
My website : http://help-freecad-jpg87.fr updated 2023/11/06
Re: how to draw a pair of glasses
Can you share it on a publicly available fileshare service like dropbox?
NormandC
Post by NormandC »
jpg87 wrote:I challenged myself to draw this pair of glasses proposed in the French forum (Postby kryscosne » Thu Jan 26, 2017 3:22 pm) :
Forum link: https://forum.freecadweb.org/viewtopic.php?f=12&t=20243
jpg87 wrote:I followed the advice of NormandC to obtain profile corresponding to the curvature and curve of the glass (steps 1 and 2) :
Unfortunately, this method of creating a sweep path from a Part Section of two surfaces creates a B-spline curve with an excessive number of knots. Therefore it takes a lot of time to generate this sweep. I once read a post by DeepSOIC that this was fixed in OCC 7+, but I've tested in latest master with OCC 7.1.0 and it still takes a long time to generate the sweep (4 minutes now and still counting).
Chris_G
Post by Chris_G »
I made 2 tools that would help in that kind of situations in my Workbench : CurvesWb (it is also available in the addon manager) :
- discretize edge : exposes the full python "discretize" function as a parametric object
- approximate points : exposes the full "approximate" function as a parametric object
I don't encourage anybody to use my workbench (full of buggy, half-finished tools) but these 2 tools are, I think, pretty stable and could help in that kind of situation.
jpg87
Post by jpg87 »
Thank you for your answers.
Here is a link where you can retrieve my file if you want :
https://www.dropbox.com/s/22rtecm60sk3h ... FCStd?dl=0
Attention: It has not been purified; It contains various sketches and worktops that may no longer be used after my many tests and trials.
I will test the tools of Chris_G and above all try to better understand the mathematical properties of the B-spline curves.
Chris_G
Post by Chris_G »
The section curve (from "contour" and "galbe") is not very good : degree 1 and 6935 control points !
I don't know if this is the origin of your problems later in your modeling process, but this is not a very good sweep path anyway.
DeepSOIC's Section macro should create a better result.
I've not been able to run the macro (no result ... I don't know why).
You'll be able to get a far better curve with the 2 tools of my workbench I talked above.
Below is a curve I got that way : degree 5, 51 control points and C2 continuity.
Chris
better-section.fcstd
(9.8 KiB) Downloaded 46 times
microelly2
Post by microelly2 »
There is a low complex example of a glass
http://freecadbuch.de/doku.php?id=blog: ... gen_teil_2
I will have a look atyour data to see how to create the surface templates from that.
jpg87
Post by jpg87 »
Sorry for this delay in my response, I ran out of time.
Thanks to Chris_G :
I did not succeed in using the curve you sent me, so I rebuilt everything with simpler b-splines, and I managed to get what I was hoping for. I also took advantage of it to work in more appropriate plans :
https://www.dropbox.com/s/or1yd7vfq7bk2 ... fcstd?dl=0
Thanks also to microelly2 :
I consulted the link and I am impressed by the examples I found there.
For the moment I'm fighting with the German> French translators.
Regards,
jpg87
microelly2
jpg87 wrote: For the moment I'm fighting with the German> French translators.
Let me know which page(s) you read, then I can translate it to English.
jpg87
Post by jpg87 »
I try to translate in French some articles of the forum that interest me by writing Libre Office documents to consult them again if I need later, and if the result seems correct, to share them on the French forum .
I have some difficulties to translate the few sentences that are not in English on the page
http://freecadbuch.de/doku.php?id=Animation%20Wokbench
Moreover, a few words would be useful to me concerning the use of the tools "Abroller", "Connector", …
I have not yet had time to consult the page
http://freecadbuch.de/doku.php?id=animation:videos
on which I will probably find answers.
I have not yet sufficiently integrated the FreeCad state of mind, but I treat myself !
Thanks again.
jpg87
