dxf import problems windows version
pastmanu
Post by pastmanu »
Hi to all, i have this problem. I installed freecad in some Windows Pc's. When i try to import a dxf file in Win 10 pc Freecad does 'wire' objects, instead when i try to import a dxf file in Win 8.1 pc Freecad makes lines, arcs..etc etc.
In all Pc i installed freecad 0.16(last stable version 0.16.6706.f86.. etc etc) and the last dxf import version (1.39). I would 'wire' objects on all the import file. I've seen some posts that talk about 'wires' with lines and arcs and the problem of the order of them. They use FixWire command in python. Can it be a solution for me? How can I use it on the python command line with the selected lines(and arcs)after import?
Thanks in advance
manu
yorik
Founder
Re: dxf import problems windows version
Post by yorik »
In edit -> preferences -> import/export -> dxf you can set ifyou want lines to be imported as lines or joined into wires (join geometry, or group by layer). You can also explode wires into individual lines/arcs with Draft Downgrade
pastmanu
Post by pastmanu »
Thankx for your answer. I try all the options(dxf importer options) but with win8.1 does not work. I attach a drawing as an exemple. When i import in freecad i see only line and arc. If i try to join the external perimeter(upgrade in draft) freecad does not make 'wire' and say me (on report) "it's impossible to upgrade the object". I try also without check on "legacy importer" and it does not work anyway. My co-workers with Win10 work it. I tried with different versions of dxf but I have the same results. The only way for me, but it is laborious, is delete some lines in draft and redraw them.
How can I fix it?
Thanks in advance
manu
Untitled3.dxf
(38.04 KiB) Downloaded 87 times
yorik
Founder
Post by yorik »
There are open gaps in your drawing, that prevent FreeCAD from closing wires. You might try to tweak the Preferences->Draft-> precision and tolerance values, it might work, but the best way would be to fix things in the dxf file itself.
Screenshot from 2017-04-27 13-14-44.png (43 KiB) Viewed 2157 times
sgrogan
Post by sgrogan »
pastmanu wrote:I try all the options(dxf importer options) but with win8.1 does not work
Try this, set you prefs like this,
Key are Sketches and Join geometry. Close and re-open FreeCAD for the prefs to take.
Import your dxf. Delete or hide everything except "Sketch". Select "Sketch" in the Tree. From the Sketch or Part Design menu choose "Validate sketch..." Click on "Find" under missing coincidences. As yorik has pointed out you will find about 102 missing coincidences, click fix.
Now you can pad, extrude, or convert the sketch to draft.
OS: Windows 7
Word size of FreeCAD: 32-bit
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
"fight the good fight"
