Sketcher transactions
microelly2
Post by microelly2 »
I play with sketches to get invalid configurations and roll back (undo) to the last version.
this works sometimes but not always.
Should undo/redo work in Sketch edit mode ? Then there are some bugs :roll: .
Otherwise i wonder what are ways to roll back from a corrupt sketch?
Is there a python method to paste and copy the whole sketch?
Is there a python way to get more information what causes the error in a sketch recalculation?
DeepSOIC
Re: Sketcher transactions
Post by DeepSOIC »
Undo should work.
Could you please describe step-by-step procedure of a failing undo?
microelly2
DeepSOIC wrote:Undo should work.
Yes, then I will look how to track the failures.
Founder
Post by wmayer »
Problems may occur when undoing/redoing changes while in edit mode. There are apparently some actions that don't reopen a new transaction after a change was committed.
Here a harmless issue:
  • add a line
  • create a length constraint
  • move the length constraint
When looking in the undo stack there is a transaction for the move of the constraint but when undoing it the constraint doesn't move back.
microelly2
wmayer wrote: When looking in the undo stack there is a transaction for the move of the constraint but when undoing it the constraint doesn't move back.
Can i look from python into the transaction stack?
Does it make sense to leave the edit mode and reenter it after every change?
Founder
Post by wmayer »
App.ActiveDocument.UndoNames
No! This will make it quite inefficient.
