Trouble thickening lofted surface
JV_3D
Post by JV_3D »
spacether wrote:
Re: New Part Offset and Part Thickness tools
Postby normandc » Thu Nov 29, 2012 3:18 am
A question: in the CAD software I use at work, there's a "thicken" command to give thickness to a surface or a shell and transform it into a solid. The edges are extruded normal to the surfaces. Could Part Thickness be eventually modified to add this functionality? Or does the OCC API not support this?
I found a way to parametrically thicken a surface using the existing v .13 build.
It's a little bit of a hack but it works.
1) make surface 1, I used separate sketches and lofted a surface
2) offset the surface without a fill
3) switch t the draft module and use the facebinder to clone each face
4) loft between two faces that were cloned with facebinder, make sure to set solid to true
You now have a thickened solid which you can use in boolean operations. See images below demonstrating it:
Hello, sorry to recover this old thread but I needed this since I got an issue with offset with a lofted surface, when I try to fill the offset it did it work; I find this option with facebinder but it doesn't work either, it just create a face between the surfaces but not a solid, could you please verify if this work at this time? I guess maybe it work with simple surface but the example you showed look like a complex face.
I am using v 0.16 with Windows x64
Thank you
splitted off https://forum.freecadweb.org/viewtopic. ... 8&start=10 --DeepSOIC
EDIT:
Here, I update images to clarify the trouble I am getting, In the images use offset of 15mm to make the image more clear but is not working with any less (I need 4mm)
As you can see it only fill the top of the surface but nothing else
JV_3D
Re: Trouble thickening lofted surface
Post by JV_3D »
I upload some images to clarify the issue I am having
Thanks in advance for any help
