View property Angular Deflection can freeze FC
Chris_G
Post by Chris_G »
I didn't found any bug report about this in the tracker.
If I want to modify the angular deflection in the view panel of an object, i can freeze FC.
Steps to reproduce :
Let's say the angular deflection is set to 5°
- put the text cursor in front of the 5
- delete the 5
- FC freezes ( maybe starting a super-mega-fine tesselation ? )
- you can go for a hundred coffees :D
In case this info is relevant, I have a french locale, with ',' as the decimal separator.
OS: Ubuntu 17.04
Version: 0.17.10949 (Git)
Build type: None
Hash: 20828b3cb31557301da66465363717e1e66c28c7
Python version: 2.7.13
OCC version: 7.1.0
Founder
Re: View property Angular Deflection can freeze FC
Post by wmayer »
What kind of part object do you have for testing? Apparently with a standard cylinder I don't see this problem. So, obviously it must have a bit more complex shape.
Chris_G
Post by Chris_G »
It was a pretty simple BSpline surface.
Here is one that freezes.
Thanks.
Surface.fcstd
(8.22 KiB) Downloaded 44 times
EDIT : I just tested on a cylinder, and I have the same freeze.
I renamed my .FreeCAD folder -> no freeze on the cylinder but still freezes on the BSpline surface ???? Weird
Founder
Post by wmayer »
Confirmed.
Chris_G
Post by Chris_G »
Thanks for the confirmation.
Bug report :
https://www.freecadweb.org/tracker/view.php?id=3000
Founder
Post by wmayer »
The minimum angle is now 1 deg to avoid to run it forever. Depending on the shape this still may take some time.
Chris_G
Post by Chris_G »
Thanks Werner.
