Hi all,
I am having some trouble but probably you will immediately see what I am doing wrong here.
Freecad says that the sketch is fully constrained but when I look on it I can tell that is it not.
The issue is then that sometimes when I open the file, the sketch is changed to the other solution.
Please see the attached file.
Description:
The small circle is located on the line of the larger circle in the first quadrant.
But the constraints applied are also fulfilled when the smaller circle is in the fourth quadrant.
Any ideas?
Have a nice day,
BR
Tomas
I am using:
OS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
Freecad says "Fully constrained sketch", but it's not
- fullyContrainedSketch.FCStd
- (2.99 KiB) Downloaded 51 times
Re: Freecad says "Fully constrained sketch", but it's notH
Fully constraint doesn't mean that the solution is unique. It means there is no more an infinite number of degrees of freedom solutions.
Edit: Thanks DeepSOIC, it should be solutions not DOF.
Ok, that's a pity. I knew it was something I misunderstoodchrisb wrote:Fully constraint doesn't mean that the solution is unique. It means there is no more an infinite number of degrees of freedom.
Thanks,
BR
/Tomas
- microelly2
If you have at least one distance constraint then there is a quadradic equation in the system with 2 solutions,Tomas wrote: The issue is then that sometimes when I open the file, the sketch is changed to the other solution.
Any ideas?
to avoid this you can replace some constraints
(example use an angle and deactivatet the distance (blue), then invert the angle and roll the constrains back angle blue and distance red )
I had the same problems some day ago and I will upload the example when I'm home again.
- DeepSOIC
Correction. 1 degree of freedom means the solution space is 1-dimensional. "Space" implies an infinite number of solutions. Finite number of solution isn't a degree of freedom. And sketcher will tell you the sketch is fully constrained if there are no degrees of freedom, and it can't detect there are extra discrete solutions.chrisb wrote:Fully constraint doesn't mean that the solution is unique. It means there is no more an infinite number of degrees of freedom.
Ah, yes ofcourse that is how to do it!microelly2 wrote:If you have at least one distance constraint then there is a quadradic equation in the system with 2 solutions,Tomas wrote: The issue is then that sometimes when I open the file, the sketch is changed to the other solution.
Any ideas?
But if for instance the value comes from a spreadsheet I will need to do the math myself, but I can, so that is no issue.
Great!
Thanks and have a nice weekend!
BR
Tomas
- microelly2
here my example file and the demo script
open the sketch
the copy and paste the srcipt to the python console
it demonstrates how to flip between the two solution s
open the sketch
Thank you very much for your effort!microelly2 wrote:here my example file and the demo script
open the sketch
viereck_unbestimmt.fcstd
viereck_unbestimmt.py
Maybe one should learn writing pythonscripts!
I wish you a great day,
BR
Tomas
- microelly2
There are often situation where the gui does not support special actions but FreeCAD has a large programming api.Tomas wrote: Maybe one should learn writing pythonscripts!
writing scripts allows you to automate common tasks.
And python is a very fast way to write scripts.
