I think "Arc" can be edited, but what about "arc of ellipse"? This link
https://www.freecadweb.org/wiki/Sketcher_Arc_of_Ellipse
Suggests its all done by super-precise clicking.
Having created an (approximate) "Sketch → Sketcher geometries → Create an arc of ellipse",
I eventually want to make the arc "correct" - an actual length for the minor/major radii, an actual exact angle, and a way to define rotation. So, I need to rotate the ellipse about a normal to its centre, move the centre then edit the arc angle etc
What I'd like to do is use an edit dialog. I thought maybe if I used Draft WB, an Editor would pop up.
I appreciate that "sketcher" is not used for exact, measured elements, just relative angles etc.
Here is my aim:
1. Create an "Create an arc of ellipse"
2. Later on, edit it
Obviously, it's easier to get precise results with edit boxes or up/down controls than it is to hand-draw a "right first time" arc.
Regards
Stephen
How can I edit "arc of ellipse"?
Re: How can I edit "arc of ellipse"?
Add appropriate constraints, like any other Sketcher geometry, ..... are constraints not working on arc of elipse for you?
Hello Stephen,
To define your arc of ellipse you need to toggle its internal geometry (the ellipse axes represented as blue construction lines) back to visible. It seems that you deleted them. There's an icon for that in the Sketcher toolbar to make them reappear.
That statement is totally wrong. On the contrary, the whole purpose of the Sketcher is to define geometry with the most precision possible, all in the 3D view. No edit dialog is necessary.sjb wrote:I appreciate that "sketcher" is not used for exact, measured elements
- FC_Sketcher_Arc_of_Ellipse.jpg (99.28 KiB) Viewed 1783 times
Hello Normand
Thank you for your reply. Here, Sketcher Workbench, it says
I have now created a new sketch, and added an arc of ellipse. I can see the construction lines, but I can not see where to type in precise values.
Regards
Stephen
That is why I (mistakenly) thought "...sketcher is not used for exact, measured elements...".The Sketcher moves away from this logic. Objects do not need to be drawn exactly as you intend to, because they will be defined later on by constraints. Objects can be drawn loosely, and as long as they are unconstrained, can be modified.
Is this still within Sketcher?...all in the 3D view...
Can I type in values somewhere else - double-click somewhere first maybe? ThanksNo edit dialog is necessary
Regards
Stephen
If using FreeCAD 0.16, in Part Design WB select the green line again in your screen grab, click a Constraint such as this one:
A dialogue window will open, and you can type in the desired value:
I would strongly recommend to work through some of the tutorials - video or classical. They show how to use e.g. the Part Design Workbench. bejant has a link in his footer, give it a try.
It has turned out to be important that you actually work through the tutorials, it helps but is not sufficient to watch them.
+1chrisb wrote:I would strongly recommend to work through some of the tutorials
Thanks all for your guidance.
