hello,
i try to set dimension in my object, but it's not precise and i don't know if dimension is correct.
my object is created by multi booleen operation and i have not the object dimension.
how i can dimensionnate my object like is drawing ?
and else,
i would like contribute to your project.
i am no a programmer same i like.
but i try to traduct documentation in french, i am not a good english speaker but ...
say me what i do for traduct peraps the first document need to read.
and i try.
i think i can use better freecad if a work in traduc of documentation.
and i have a big project to draw and i hope freecad ca draw it.
best regard,
jean-christophe.
easy set dimension in 3D object ??
Re: easy set dimension in 3D object ??
Hi Jean-Christophe,
The dimension tool still has some problems when displayed in 3D (The dimension text is not correctly aligned) but it IS precise, if you take your measurement points correctly (that is, in most cases, snapping to vertices).
For translating the documentation, I think the wiki has everything there already: http://meta.wikimedia.org/wiki/Meta:Interlanguage_links
Basically it looks like, if you want to translate a page you just create a subpage with your language code.
For example, you want to translate the page About in french, you create a About/fr page, and the wiki takes care of all the linking.
Hmm I just did a little test here: http://sourceforge.net/apps/mediawiki/f ... torials/fr but I still didn't find how that page appears as "other languages" in the sidebar.
I'll try to find out how it works...
Cheers
Yorik
Cheers
Yorik
