Save a STL file with multi-regions
Moderator: oliveroxtoby
- wandererfan
Re: Save a STL file with multi-regions
issue #002459 maybe?
I just came across this topic, and would like to contribute my own thoughts on the matter.
One other possibility is to export all the single regions to separate files and merge it outside of FreeCAD by using the 'cat' command in terminal (when using Linux) or the 'type' command (when using Windows).
cat obj1.stl ob2.stl obj3.stl > all_obj.stl
That's my approach, and it works for me when dealing with Open FOAM, meshing and CFD.
OS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
OS: Windows 7
I am facing the same issue as many cfd-people in this forum: For flow simulations in OpenFoam I need to be able to export the surfaces of my geometry individually as either .stl or .obj files, since the different surfaces will be assigned to different boundary conditions. As virengos suggests, the files can then be collected or imported to OpenFoam individually.
The big advantage of freeCad for cfd applications would be the treatment of geometry surfaces as part objects allowing their individual export.
This is the one reason why I tested freeCad. Until now, only the cad editor of Comsol Multiphysics allows me to do just that.
I just stumbled across this thread. If I understand it right, only a Export of each single face of a shape is needed. This can be done with a macro.
You can also create a macro and add a button to the gui. A lot of Information how this can be done can be found here and https://www.freecadweb.org/wiki/Online_Help_Toc here.
I hope this helps.
# Purpose: export each face of a selected shape to .stl file
#paste the import statements first:
import FreeCADGui
from FreeCAD import Base, Console
import FreeCAD
import Part
import DraftGeomUtils
import Draft
import time
import math
import os
#pre work: just create a folder tmp in FreeCAD 0.15 folder, single faces will be saved here
#first: select the shape for exporting and paste this 2 lines into the console and hit enter
sw = FreeCADGui.Selection.getSelectionEx()[0]
obj = sw.Object.Shape
#second: paste following lines into the console
for face in obj.Faces:
unique=str(time.time())
hash=str(face.hashCode())
#edit your filename here
filename='D:\\Anwenderprogramme\\FreeCAD 0.15\\tmp\\001_TIME_'+unique+'_Hash_'+hash+'.stl' #create unique filename
face.exportStl(filename,0.3)
parameters for stl export can be found here: search "exportSTL"
at https://github.com/FreeCAD/FreeCAD/blob/4664e5bb483404b064e8de59ce0ca3161482e9a1/src/Mod/Part/App/TopoShapePyImp.cpp
#single file for each face is created in D:\\Anwenderprogramme\\FreeCAD 0.15\\tmp folder
#single faces can be selected too, just select the face of interest:
sf = FreeCADGui.Selection.getSelectionEx()[0]
face=sf.SubObjects[0] #sf.Object.Shape
I hope this helps.
The new CFD WB might provide some help in this regard: https://forum.freecadweb.org/viewtopic. ... 6&start=40
It creates a multi-element stl instead of exporting separate stl files for the faces. This ensures a watertight geometry and allows for feature edge extraction.
this is may be interesting in the regard of this topic ... https://forum.freecadweb.org/viewtopic.php?f=3&t=16855
Does anybody know how this thing works?johan wrote: ↑Thu Jun 01, 2017 9:14 am The new CFD WB might provide some help in this regard: https://forum.freecadweb.org/viewtopic. ... 6&start=40
Hello,
I am looking for a (quite simple) procedure via FreeCAD generating STL files and surface/ Volume patches to mesh multibodies geometry using snappyHexMesh.
Is there something already existing?
I found a lot of solutions on cfdonline but I am a little bit lost..
Best regards
Julien
Best regards
Julien
Not sure if it is still an issue. But if you want to convert a single STL to a multi-region STL, simply usecfdfoundation wrote: ↑Sat Jan 10, 2015 4:39 pm This post addresses a very important topic for people using FreeCAD for engineering simulation, specifically computational fluid dynamics (CFD) with OpenFOAM.
CFD requires a computational mesh. The mesh can be generated within OpenFOAM using snappyHexMesh. snappyHexMesh uses geometry input in the form of triangulated surface files in either STL or OBJ format. Ascii STL and OBJ support "regions", or "patches". Call it what you like, it just means that triangles can be collected together under a particular name.
In the cylinder example, the triangles that make up one circular end could be labelled "inlet", the other circular end could be "outlet", and the curved part of the cylinder could be "wall". When the inside of this surface is meshed with snappyHexMesh, the resulting mesh will have boundary patches "inlet", "outlet" and "wall" on which flow boundary conditions can be applied for a CFD simulation of flow along a cylinder (pipe).
So the piece of functionality in FreeCAD that would be hugely beneficial to CFD/OpenFOAM users would be the ability to name regions of part surfaces, and the inclusion of those names with triangulated surface export. It is the ONE piece of functionality that today (Jan 2015) would make FreeCAD very attractive as a geometry generator for CFD with OpenFOAM. It would be much appreciated if the FreeCAD developers could comment on the viability/ease of such a development. (The functionality already seems to exist to highlight geometry faces, e.g. 1 of 6 faces of a box, in the GUI)
surfaceAutoPatch
