The code generates a shape. This needs to be converted to a solid shape in the Part WB before you can further use it for bool operations. I looked at the code in the console when doing so and tried to copy the same transformations into the macro, but it doesn't do the same thing.
import FreeCAD, Part, math, Draft
from FreeCAD import Base
class Antenna:
def __init__(self, obj):
''' Add the properties: Radius, Eccentricity, Height, Segments (see Property View) '''
print "Antenna::__init__"
obj.addProperty("App::PropertyLength","Diameter","Antenna","Antenna apreture diameter").Diameter=60.0
obj.addProperty("App::PropertyLength","Height","Antenna","Height of antenna").Height=20.0
#obj.addProperty("App::PropertyLength","Focal","Antenna","Focal distance to antenna base").Focal=30.0
obj.Proxy = self
def onChanged(self, fp, prop):
print "Antenna::onChanged", prop
if prop == "Diameter" or prop == "Height" or prop == "Focal": #if one of these is changed
self.execute(fp)
def execute(self, fp): #main part of script
tu = FreeCAD.Units.parseQuantity
thickness = tu('0.01 mm')
d = fp.Diameter
#f = fp.Focal
h = fp.Height + thickness
a = h / d / d * 4
f = a/a / 4 / a # we use a/a to get it into the right units
print "focal length", f
steps = 100
increment = d / 2 / steps
y = 0.0
for i in range(steps):
x1= i * increment
z1= a * x1 * x1
x2= x1 + increment
z2= a * x2 * x2
seg=Part.makeLine((x1,y,z1),(x2,y,z2))
if i == 0:
wire = Part.Wire([seg])
else:
wire=Part.Wire([wire,seg])
# move wire back to the center
seg= Part.makeLine((x2,y,z2), (0.0, y, z2))
wire = Part.Wire([wire, seg])
shell=wire.revolve(App.Vector(0,0,0),App.Vector(0,0,1),360)
# make a solid
solid=Part.Solid(shell)
solid = solid.Faces
solid = Part.Solid(Part.Shell(solid))
# apply a thickness
thick=solid.makeThickness([solid.Faces],-thickness,0.001)
#create a small cross at the focal point
#c1 = Part.makeLine((-1.0, 0.0,f.Value), (1.0, 0.0, f.Value))
#c2 = Part.makeLine(( 0.0,-1.0,f.Value), (0.0, 1.0, f.Value))
#c3 = Part.makeLine(( 0.0, 0.0,f.Value-1),(0.0, 0.0, f.Value+1))
#cross = Part.makeCompound([c1, c2, c3])
fp.Shape = thick
def makeAntenna():
doc = FreeCAD.activeDocument()
if doc == None:
doc = FreeCAD.newDocument()
antenna = doc.addObject("Part::FeaturePython","Antenna") #add object to document
antenna.Label = "Antenna"
Antenna(antenna)
antenna.ViewObject.Proxy=0
if __name__ == "__main__": #feature will be generated after macro execution
makeAntenna()
