Projecting curve onto face
danielfalck
Post by danielfalck »
Is there a way, either using the gui or with python of projecting a curve onto a face or surface?
Thanks.
Founder
Re: Projecting curve onto face
Post by wmayer »
import Part
from FreeCAD import Base
v=Base.Vector
c=Part.makeCircle(2,v(0,10,5),v(0,1,0))
s=Part.makeCylinder(4,10)
f=s.Face1
p=f.makeCylindricalProjection(c,v(0,1,0))
Part.show(p)
Part.show(c)
Part.show(s)
git commit 99d10a6
danielfalck
Thanks Werner. I see you created a method for conical projection too. Is there a way of dealing with flat faces also?
Thanks.
Founder
Post by wmayer »
import Part
v=Base.Vector
c=Part.makeCircle(2,v(5,5,5))
s=Part.makePlane(10,10)
f=s.Face1
p=f.makeCylindricalProjection(c,v(0,0,1))
Part.show(p)
Part.show(c)
Part.show(s)
The shape on what you project can be everything not just a cylinder. I used the terms "cylindrical" and "conical" from the class documentation which actually means parallel and perspective projection.
danielfalck
Ah, very good.
Thank you so much for adding this. I used to use Rhino3D and there were similar operations for projecting polylines onto surfaces. This is super cool. My intent is to use this for engraving on objects.
Founder
Post by wmayer »
I will rename the methods to "makeParallelProjection" and "makePerspectiveProjection" because it's less confusing then.
Wolpertinger
Post by Wolpertinger »
Thank you for posting this methodes....
I'm am newbie and I'm trying to find a way to model a ring with a text on (or in it), and I thought this could be smarter way instead of placing every single letter manually.... I tried to figure out how to use this methodes but I failed.
Is there any tutorial or good advice someone could give me? Thank you very much.
yorik
Founder
Post by yorik »
Thanks for that addition Werner, very useful!
*EDIT* *WOOPS* Just notice it was pretty old! How come I didn't see it! Thanks anyway! ;)
ujjwal
Post by ujjwal »
Please suggest the way to wrap a spline ( 2d) on a 3d surface. This is similar to CATIA's develop option.
I am a newbie to the design world, hence advice how to handle this codes ( files) also.
Regards
Ujjwal
OS: Windows 7
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
DeepSOIC
Post by DeepSOIC »
Hmm, interesting!
