i try to modelize an helical slot:
my drafts
22,5 degrees rotation:
http://img11.hostingpics.net/pics/259232print.jpg
90 degrees:
http://img11.hostingpics.net/pics/464973Capture.png
sorry for my english
OS: Linux Mint 13 Maya
Platform: 32-bit
Version: 0.14.3402 (Git)
Hash: dc0bbee020a72a0ad1f868527c7af6a4cb06184e
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
[SOLVED] helical slot
Re: helical slot
Greetings,
The following is an approximation; you can download the .FCStd model attached at the end of this post and change the constraints to your liking: OS: Windows XP
Platform: 32-bit
Version: 0.14.2370 (Git)
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
Platform: 32-bit
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
- 20140413a_SNAL.FCStd
- (304.6 KiB) Downloaded 75 times
Re: helical slot
22,5 degrees:
http://www.hostingpics.net/viewer.php?i ... degres.png
...ok
45 degrees :
...ok
90 degrees:
...oops !
...ok
45 degrees :
...ok
90 degrees:
...oops !
Re: helical slot
For 90 degrees you may need to add a few helper sketches in between to guide the loft correctly...
Re: helical slot
my results:
- 45 degres.fcstd
- (174.78 KiB) Downloaded 104 times
- 22,5 degres.fcstd
- (136.13 KiB) Downloaded 111 times
- 90 degres.fcstd
- (283.98 KiB) Downloaded 119 times
Re: helical slot
The 90 degree appears to be OK but the file doesn't have included all the steps you took so as to create the model...
For the 45 and 22.5 degree models all you need to do is change to the Part workbench and boolean difference the filleted piece from the tube. The tube will be the item you want to select in the left side, and the Fillet001 will be in the box on the right.
- 20140414bu_SNAL_22,5deg.fcstd
- (228.71 KiB) Downloaded 67 times
- 20140414au_SNAL_45deg.fcstd
- (272.5 KiB) Downloaded 71 times
