I would like to tessellate a shape with local cords.
I think the placement (transformation-matrix) will be transformed into each point inside tesselation() by FreeCAD.
Now i have to create a second shape with transformGeomtry and the inverted Placement just to undo something which will done later.
The reason is, that i would like to transfer shape´s to a external application and i would like to transfer local cords for triangle meshes and transformations separate.
Is there a way do do this?
Cheers,
Jack - not really
tessellate() with local cords ?
Re: tessellate() with local cords ?
First of all you need a definition of "local coords". Assuming you have a face where e.g. the 1st derivative of the underlying surface is defined in (0,0). Then you can build a local coordinate system for your shape this way:
v1...axis in u-direction at (0,0)
v2...axis in v-direction at (0,0)
v3...normal at (0,0) or cross product of v1 and v2
p...surface point at (0,0)
The vectors v1,v2 and v3 are perpendicular to each other so that they can be used to define your local coordinate system with p as origin.
So, you can define a 3x3 rotation matrix R=(v1,v2,v3) and the translation vector p and thus the transformation
To get the transformation from global to local coordinates you need the inverse of the above transformation. Since R is a so called orthonormal matrix its inverse is equal to its transposed matrix.
In Python it looks like:
Now, you can tessellate your shape and apply the transformation to each of your point to get it expressed as local coordinate.
Here is a full script with a plane as example which we transform first
X' = R * X + p
X = R^T * X' - R^T * p
from FreeCAD import Base
face = ... # a topo face as reference
(v1,v2) = face.derivative1At(0,0)
v3=face.normalAt(0,0)
p=face.valueat(0,0)
mat = Base.Matrix()
mat.A11 = v1.x
mat.A21 = v2.x
mat.A31 = v3.x
mat.A12 = v1.y
mat.A22 = v2.y
mat.A32 = v3.y
mat.A13 = v1.z
mat.A23 = v2.z
mat.A33 = v3.z
mat.A14 = -(v1.x*p.x + v1.y*p.y + v1.z*p.z)
mat.A24 = -(v2.x*p.x + v2.y*p.y + v2.z*p.z)
mat.A34 = -(v3.x*p.x + v3.y*p.y + v3.z*p.z)
(v,f)=face.tessellate(0.01)
for i in v:
print mat.multiply(i)
import Part
face=Part.makePlane(10,10)
r=Base.Matrix()
r.rotateX(1.0)
r.rotateY(1.0)
r.rotateZ(1.0)
r.move(12,23,34)
face.Matrix=r
(v1,v2)=face.derivative1At(0,0)
p=face.valueAt(0,0)
mat = Base.Matrix()
mat.A11 = v1.x
mat.A21 = v2.x
mat.A31 = v3.x
mat.A12 = v1.y
mat.A22 = v2.y
mat.A32 = v3.y
mat.A13 = v1.z
mat.A23 = v2.z
mat.A33 = v3.z
for i in v:
First off all: For me everything works fine.
Just the "scale" could be a problem.
This is for my understanding and may be for optimization.
I am not much experienced in this and only know little about the FreeCAD/OCC Kernel.
I am familiarized to use homogeneous transformation matrix within OpenGL and scene graphs.
What i mean with local coordinates is:
Now i want to export the shape to my application. All in "local" coordinates and additional i will transfer a 4 x 4 homogeneous transformation matrix (for position/rotation/scale)
Afterwards, i would like to change the position/rotation/scale of the shape in my application.
After change i would like to update the FreeCAD drawing (shape) by ONLY transferring the 4 x 4 homogeneous transformation matrix back to the shape.
The placement is a 4 x 4 homogeneous transformation matrix, but unfortunately it does what is´s name sounds like:
place.. + rotation, but no scale.
Although it seems it could, but the placement implementation seems to prevented this (ignoring the diagonals scaling cells).
If i would have a free wish this would be:
Now i am doing something like this to "un-transform" the shape placement (i think something like your suggestion):
To Transfer scaling back to FreeCAD, i don´t have have a better idea then:
but this would generate other tessellation-coordinates then before (the next time)
Cheers,
Jack - not really
Creating a Shape (Box size 100 overall, zero point at middle). So all coordinates will be in between +/- 50.
This i would call local.
Setting the pos-placement to (X=200) will produce coordinates during tessellation from +250..150 in x-axes.
This i would call world.
Shape.SetTransform4x4Matrix(Matrix) # modifying translation/rotation/scale
and
Matrix=Shape.GetTransform4x4Matrix()
and last
..tesselate(quality,LocalOrWorld) #with or without the Shape transformation matrix
pn=FreeCAD.Placement()
p=shapeIn.Placement #shapeIn is the incoming shape
if pn.Rotation.Q==p.Rotation.Q and pn.Base==p.Base:
# identity matrix, nothing to do
shape=shapeIn
else:
# remove Placement from shape
m=shapeIn.Placement.toMatrix()
m.invert()
shape=shapeIn.transformGeometry(m)
for f in shape.Faces:
av=f.tessellate(0.8)
.. removing scaling from my transformation matrix
.. update transformation matrix to FreeCAD Shape-placement # position and rotation will be ok
.. making a shape.scale() with the scaling part of original transformation matrix
Cheers,
Jack - not really
in addition:
Maybe it´s not a good idea to change the scale of shape.
If it´s feature-based then its property´s should be changed to get a new "scale"
So, in other words: the gravity center of the object lies in the origin and is aligned to the coordinate axes.Creating a Shape (Box size 100 overall, zero point at middle). So all coordinates will be in between +/- 50.
For a shape you can use the method scale() which sets the internal placement of the shape -- in OCC this placement is realized by the class TopLoc_Location. Afterwards you can use the attribute "Matrix" instead of "Placement" and this matrix also contains your scale factor.The placement is a 4 x 4 homogeneous transformation matrix, but unfortunately it does what is´s name sounds like:
place.. + rotation, but no scale. Although it seems it could, but the placement implementation seems to prevented this (ignoring the diagonals scaling cells).
The Matrix attribute does exactly this.If i would have a free wish this would be:
and
and last
The scaling could lead to strange results. Especially for some more complex geometries you can create self-intersections or even worse things.Maybe it´s not a good idea to change the scale of shape.
Hi Werner,
Ok, now i think its clear. It is the same topic as: viewtopic.php?f=3&t=655&p=4502#p4502
Cheers,
Jack - not really
Cheers,
Jack - not really
