Help with DXF export
Re: Help with DXF export
Hello ive made another bracket. done what you said with max spline to 6 tried to save it as dxf in a folder and it doesnt save anything ? i cant find it anywhere like it hasnt saved ?
i go into libre cad and look for it to open it and cant find anything ?
Anychance you can have a look at this bracket and see if im missing some thing thanks
- standard Kawasaki 1.FCStd
- (11.39 KiB) Downloaded 55 times
Just one other thing i couldnt find import/ export tab ? on the intsructions from that previous post ? there was a dxf tab where i found max spline setting ?
Here is your file
Please look at this post and do what I was suggesting over there. viewtopic.php?f=3&t=7160&p=58102#p57936steve49suzuki wrote:Hello ive made another bracket. done what you said with max spline to 6 tried to save it as dxf in a folder and it doesnt save anything ? i cant find it anywhere like it hasnt saved ?
The report view is giving me errors when I try to export your file to DXF with the current stable version. As previously mentioned, there seems to be a bug with the exporter that was fixed yesterday in the main source code.
It exports fine in FreeCAD compiled from today's sources.
That's the one and the same, the name of the tab was changed before the stable release.steve49suzuki wrote:Just one other thing i couldnt find import/ export tab ? on the intsructions from that previous post ? there was a dxf tab where i found max spline setting ?
Thanks the other bracket and this one opens in libre cad thats great
i will try the other thing you suggested aswell and let you know.
I think its easier to let you do it for me lol
thanks again for help
Draft workbench activated
Draft workbench deactivated
DXF libraries not found. Downloading...
downloading https://raw.github.com/yorikvanhavre/Dr ... olorMap.py ...
Download of dxf libraries failed. Please download them manually from
https://github.com/yorikvanhavre/Draft-dxf-importer
and place them in your macros folder
downloading https://raw.github.com/yorikvanhavre/Dr ... Objects.py ...
downloading https://raw.github.com/yorikvanhavre/Dr ... Library.py ...
downloading https://raw.github.com/yorikvanhavre/Dr ... fReader.py ...
File "<string>", line 4, in <module>
<type 'exceptions.TypeError'>: Export of this object type is not supported by Drawing module
Stack Trace: Traceback (most recent call last):
__objs__.append(FreeCAD.getDocument("standard_bobbins").getObject("Pad"))
>>> import importDXF
>>> importDXF.export(__objs__,"C:/Users/Steve Harper/Pictures/Herper Street/new 123.dxf")
>>> del __objs__
>>> __objs__=[]
>>> import importDXF
>>> del __objs__
>>> import importDXF
>>> del __objs__
>>> __objs__=[]
>>> import importDXF
>>> del __objs__
Thanks for doing as I asked, because now we know what's wrong!
FYI those are the files required by the DXF import/export utility. For licensing reasons, they are not bundled with FreeCAD and they are downloaded before use.
I suggest you do as the message says, that is downloading those files manually. On that link, there is a "Download ZIP" button at the right of the page. Or here's the direct link: https://github.com/yorikvanhavre/Draft- ... master.zip
Extract the ZIP file, and move the files it contains into your FreeCAD personal folder. I'm not sure where it's located on Windows, possibly in "C:\Users\yourUser\Application Data\FreeCAD" or in "\users\your-user-name\data\roaming\FreeCAD" or something like that. If it's not there, do a desktop search for the files "system.cfg" and "user.cfg", they will be in that folder.
Next restart FreeCAD and try to export to DXF again.
I've seen this before. I don't know why, downloading these files seem to cause problems on Windows.steve49suzuki wrote:Download of dxf libraries failed. Please download them manually from
Ok thanks will try it later
Hello link doesn't work .
