Extrude lenght relative
is it possible to extrude a sketch in Part workbench relative to anything?
I try to keep everything as parametric as possible.
I have a 'basic' solid on which I can put the sketches and 2d construct relative to this basis.
Now I would like to extrude the sketch let's say to a given face of that basic solid.
The idea is:
changig dimensions of the basic solid (already) gives automatic adaption of the sketches and (desired) the extrusion lengths.
Thx
Alex
OS: Debian GNU/Linux 7.6 (wheezy)
Version: 0.15.3967 (Git)
Hash: cef2c1bc8c0f342b86acec1704e8259c4948462a
Python version: 2.7.3
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.2
The idea is:
Thx
Alex
Qt version: 4.8.2
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.5.2
Re: Extrude lenght relative
No directly. You have to use a spreadsheet and control the parameters with that. Inside the spreadsheet you can use complex expressions.
For an example look here: http://www.freecadweb.org/tracker/view.php?id=1703
If you map a sketch on your basic solid, any PartDesign feature applied to the sketch will be fused to the basic solid.alex::freecad wrote:I have a 'basic' solid on which I can put the sketches and 2d construct relative to this basis.
Since the PartDesign feature is based on this "basic solid", you can extrude your Pad by choosing "Up to face" option.
I tried this before, it is not working. I can not pad to face (the faces of the basic solid are not selectable.If you map a sketch on your basic solid, any PartDesign feature applied to the sketch will be fused to the basic solid.
Oh, this is what I need! I read somewhere that the feature is planned, but not finished, and I overlooked it in the workbench drop down.spreadsheet
Thank you for opening my eyse!
Alex
Then this is a bug and it should be reported.alex::freecad wrote:I tried this before, it is not working. I can not pad to face (the faces of the basic solid are not selectable.
viewtopic.php?f=3&t=5236
Just to be sure before reporing a misuse as bug:
- I start a new project
- In the part workbench I add a cube, select one face
- switch to sketcher hit 'create new sketch'
- in there, I add a circle
- switch to part design
- select the sketch and choose pad
- change option to 'up to face'
- now i'm not able so click-select a face of the cube
how is the intended way to select a face?
- sketch_pad.fcstd
- (6.1 KiB) Downloaded 32 times
Have you clicked on the "Face" button to select the face? It works on your example.
Okay,
I think I have found a case where the "Up to face" option is not working when it should. I will post back with an example file.
yes, i tried to click the 'face' button first, but that changes nothing (for me)
When I try to Pad "Up to Face", and click the Face button, I'm unable to select a face in the 3D view.
Typing the face name into the Face field allows Pad "Up to Face" to work successfully.
OS: Ubuntu 12.04.5 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
The last Pad in the attached file was done that way:
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
- 20140831a_UpToFace.fcstd
- (24.78 KiB) Downloaded 38 times
