no circle point center when use sketch on new face module
OS: Ubuntu 14.04.1 LTS
Word size: 64-bit
Version: 0.14.3702 (Git)
Branch: releases/FreeCAD-0-14
Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406
Python version: 2.7.6
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.0
Word size: 64-bit
Qt version: 4.8.6
OCC version: 6.7.0
Re: no circle point center when use sketch on new face modul
[quote="The "IMPORTANT: Please read first before asking for help" topic"]Also please try to be clear in describing your problem, and don't spare details. This will avoid back-and-forth exchanges and save time for everybody.[/quote]
(just a guess)
Mark
Re: basic problems
Word size: 64-bit
Qt version: 4.8.6
OCC version: 6.7.0
I cannot see CenterPoint of Circle when I used sketches on face
where is red or green point of circle
I cannot setting preference to solve that...........
็้help.... i need somebody help.....
Word size: 64-bit
Qt version: 4.8.6
OCC version: 6.7.0
Hi Iwill
I moved your post above to this topic, which you had already created...adding basically the same question to a very old topic or double posting anywhere else on these forums is annoying and a waste of everyone's time.
If you want an answer then do what you were told here...give us some information...
Your first post was so empty of content I nearly deleted it thinking you must be a spammer or something...then now you finally give us some small information but I still don't know what you are talking about...it works for me if you mean what I guess you might mean...this is a new sketch attached to the face of a Pad from a previous sketch, the newer sketch is in edit mode and I added a circle to it...as you can see the centre point obviously works and is visible.
Post a detailed description of exactly what you are talking about, perhaps a fcstd file and some screen shots might help.
Version: 0.15.4097 (Git)
Hash: 4de77a921a7bf5f756063d08bc4b1341d04ae5e6
Qt version: 4.8.6
OCC version: 6.7.1
Qt version: 4.8.6
OCC version: 6.7.1
I tried the above in 0.14.3702 and it works fine.
Word size: 64-bit
Version: 0.14.3703 (Git)
Branch: FreeCAD-0-14
Hash: c6edd47334a3e6f209e493773093db2b9b4f0e40
Qt version: 4.8.6
OCC version: 6.7.0
I also tried this with External Geometry...it works fine in both Master and 0.14.3702.
Are you seeing any red dots on anything? e.g. the ends of line? If not what is your GPU and if Nvidia or ATI/AMD are you using the open source drivers or the proprietary drivers?
Word size: 64-bit
Qt version: 4.8.6
OCC version: 6.7.0
Greetings iWill,
The center point of a circle, endpoints of line segments, arcs, etc. are only visible when the Sketch is being edited.
To edit a sketch, double-click it in the hierarchy tree, or right-click it and select "Edit Sketch from the pop-up menu.
Does this help?
I'll take a guess:iWill wrote:I cannot see CenterPoint of Circle when I used sketches on face
Does this help?
I believe I have the same problem as iWill, but I have some additional details.
I create a box, select a face, create a sketch, and draw a circle on the face. No center point is visible, only the circle. If I click near the center I can select the point and perform other actions, it just isn't visible. If I draw a circle within the same sketch but outside of the face, the center point appears as expected. Line segments are the same way - on the face I can't see end points, but off the face they're visible.
Screenshot with the two circles, with and without center point:
System info:
OS: Linux Mint 17 Qiana
Word size: 64-bit
Qt version: 4.8.6
OCC version: 6.7.0
The graphics card is a Radeon HD 5500, and this happens with both proprietary and open source drivers.
System info:
Word size: 64-bit
Qt version: 4.8.6
OCC version: 6.7.0
I don't have this problem on Windows.
OS: Windows 7
Word size: 64-bit
Version: 0.14.3700 (Git)
Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1
Qt version: 4.8.5
OCC version: 6.6.0
Edit: I think the sketch is attached to the back face of your pad. Try rotating the view 180 degrees around the Y-axis. Or in your pad select reversed ( or deselect it if it is selected)
OS: Windows 7
Word size: 64-bit
Qt version: 4.8.5
OCC version: 6.6.0
"fight the good fight"
Hi,caffeineslug wrote:I believe I have the same problem as iWill, but I have some additional details.
there is something wrong for some people, no doubt...I am not seeing this problem here is either 0.14 or 0.15 versions below.
That is why I suspect it is GPU/driver related in some way.
Do you see this issue in all sketches? If not then perhaps you could post a demo file, although if you see this in all mounted sketches then a demo file is unlikely to help.
It is a good idea to tell us though, ...how many other people are seeing this problem?
Jim
Word size: 64-bit
Qt version: 4.8.6
OCC version: 6.7.0
Version: 0.15.4142 (Git)
Hash: 822e45c4f7cd409c4297a069a3db87db871a4763
Qt version: 4.8.6
OCC version: 6.7.1
