Hi my problem is when I try to move or copy a group of lines or profile (polyline) and the results is a mess of points that they end in other positions. Here there is a couple of screenshots showing the problem:
The first is the profile that I want to move (highlighted as green) to the other side of the wall.
This is the result, after the movement. The vertex are moved no synchronised.
I am working on FreeCAD version 0.14 in Ubuntu 14.10
Regards
problem when I move or copi a group of lines
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Re: problem when I move or copi a group of lines
which 0.14? From where? Please post Help about FreeCAD data. If you don't know how, it is explained in the first announcement topic in the help forum. Namedbitacovir wrote:I am working on FreeCAD version 0.14 in Ubuntu 14.10
IMPORTANT: Please read first before asking for help
If you are talking about the 0.14 from the Ubuntu repositories (it was only ever a development version), then upgrade to one of the PPA versions, I would recommend the "daily" PPA so you can get all the latest bug fixes and updates.
It seems to work for me, but I don't know exactly how you tried to move yours.
OS: Ubuntu 14.04.1 LTS
Version: 0.15.4121 (Git)
Hash: dd392efeb147d6df50f8d67cdca8f59981224e75
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.7.1
Could you post a file that demonstrates the problem, and the exact steps you use to get this problem?
The freecad package from the Ubuntuy 14.10 repository is broken. It's not related to the problem discussed here, but other problems (Start Center missing, thumbnails not working).
I have not yet uploaded a stable package to our Stable Releases PPA for 14.10. Utopic will not be officially out for another 3 days.
Thanks for the response. But sorry. I do not have a file with the problem. Because I moved on in the drawing. This issue happened 3 times with other polylines, so I changed these profiles to surfaces with Draft Upgrade tool to move them and extrude them. I tried to replicate the problem but I could not. Anyway, the problem happened when I made this polylines with Draft Wire tool, rotate them to 90degrees and move them with Draft Move tool. If I found the problem again I will share a file.
Word size: 64-bit
Version: 0.14.3702 (Git)
Branch: releases/FreeCAD-0-14
Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.0
Word size: 64-bit
Qt version: 4.8.6
OCC version: 6.7.0
::bitacovir::
This is really weird! When moving an object, we just change its placement, we don't touch its internal shape, so I don't understand how vertices can have moved!! If you manage to reproduce that, I'd be very curious to have a look...
