I see you've build the debug version, but I would recommend you to build for release.medju wrote:Because i compile with cmake&QtCreator and i dont have freecad.exe but i have freecad_d.exe. Of course , on windows 7 64bit.
In order to do that, change a setting in CMakeCache.txt. You'll get FreeCAD.exe. Debug version is intended for development and has optimization switched off, quite a bit of extra code that is not needed, and whopping sized pdb files and debug version of libraries.
Next, to make the thing run on some computer, you should install the MSVC redistributable package corresponding to the compiler you built FreeCAD with. That nailed it for me.
I have no Windows XP, so I can't check if it helps in this case.
