aha! Now that makes sense.jmaustpc wrote:the profile should not go all the way to the centre and the helical path should be inside the profile...so that you don't get self intersections.
Yea, I know. I'm such a noob.jmaustpc wrote:but in this specific file, your problems are actually coming from the fact that you have modelled the auger wrong
jmaustpc wrote:I doubt you would find this though, without having extended BOP checks enabled. ........ Yeah, you have to enable it via the tools menu ...parameter editor.
It was already there but set to false. I changed it to true as instructed.jmaustpc wrote:I can't remember now for sure if that parameter is there but set to "false" by default or not there at all....if it is not there then you have to add it, do so by right clicking in the windows. On the left add the sub group (only if it is not already there) exactly as you see in the image in my post linked to above.... then in the right window right click and add a Boolean type and set it to "true".
I think I understand everything now. Thank you so much, Jim!
Time for a break from the computer.
