[SOLVED]how to copy a customised toolbar between workbenches
hello
I was wondering if there is some shortcut to copy a customised toolbar between workbenches?
Tools->Customize...
Toolbars tab
I have created a tool bar called "my new favourite toolbar" and populated it with various icons from various workbenches. After doing that I found it is associated with only a single workbench - "Part Design" workbench in my case - which is fine. But is there a way to copy it to the other workbenches or write it out and read it back into them, or something? Or do I need to re-define it in the other workbenches?
And on this topic, does anyone know why the Draft workbench does not appear on the list of "Tools in the Customize display? I wanted to put the "Clone" icon onto my customised toolbar.
thanks
OS: Mac OS X
Word size: 64-bit
Version: 0.14.3703 (Git)
Branch: releases/FreeCAD-0-14
Hash: c6edd47334a3e6f209e493773093db2b9b4f0e40
Python version: 2.7.5
Qt version: 4.8.6
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
Tools->Customize...
Toolbars tab
thanks
OS: Mac OS X
Word size: 64-bit
Qt version: 4.8.6
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
- toolbar.jpg (92.65 KiB) Viewed 2683 times
Re: how to copy a customised toolbar between workbenches
Currently it's not supported to share custom toolbars with several workbenches. But it's possible to just duplicate existing custom toolbars. Therefore go to Tools > Edit parameters.I have created a tool bar called "my new favourite toolbar" and populated it with various icons from various workbenches. After doing that I found it is associated with only a single workbench - "Part Design" workbench in my case - which is fine. But is there a way to copy it to the other workbenches or write it out and read it back into them, or something? Or do I need to re-define it in the other workbenches?
On the left navigate to the path BaseApp > Workbench > "Name of the workbench" > Toolbar. Now select the item "Toolbar" (not its sub-element!) and in the context-menu go to Export parameter. Save it to a fcparam file and now go to the Toolbar of the workbench for which you want to duplicate the custom toolbar. Now import the above fcparam file and you are done.
Did you load the Draft workbench? In the customize dialog only commands of already loaded workbenches can be shown. This fact also affects your custom toolbar after a restart of FreCAD: if you add commands of a workbench which isn't loaded when the workbench with the custom toolbar is loaded these commands cannot be added.And on this topic, does anyone know why the Draft workbench does not appear on the list of "Tools in the Customize display? I wanted to put the "Clone" icon onto my customised toolbar.
Hi,piffpoof wrote:And on this topic, does anyone know why the Draft workbench does not appear on the list of "Tools in the Customize display? I wanted to put the "Clone" icon onto my customised toolbar.
It's in the Python list.
hi
can be a help here add on button in the toolbar
the discus one toolbar indepentend from the workbench
mario
mario
Thanks for that, it works perfectly. And I don't think I would have guessed where the solution lay in 1,001 nights.But it's possible to just duplicate existing custom toolbars. Therefore go to Tools > Edit parameters.
I was in the Draft workbench when I tried this as I wanted to make sure I got the correct icon - I'm trying to add the Clone icon to my custom toolbar. I've attached a screen snapshot with the pop-up menu I get which does not list the Draft workbench, it also shows the Draft workbench in the background.Did you load the Draft workbench? In the customize dialog only commands of already loaded workbenches can be shown. This fact also affects your custom toolbar after a restart of FreCAD: if you add commands of a workbench which isn't loaded when the workbench with the custom toolbar is loaded these commands cannot be added.
thanks
Dean
- draftWbLoaded.jpg (111.53 KiB) Viewed 2657 times
Pardon my ignorance, but which "Python" list? I searched "FreeCAD python API documentation" located at http://www.freecadweb.org/api/ for the keyword "navigation" (which was the best I could come up with) but got no hits.rockn wrote:Hi,piffpoof wrote:And on this topic, does anyone know why the Draft workbench does not appear on the list of "Tools in the Customize display? I wanted to put the "Clone" icon onto my customised toolbar.
thanks
Right top of Part Design in the screencapture you made.
hi, maybe we're talking at cross purposes here...rockn wrote:Right top of Part Design in the screencapture you made.
I know where to find the icon within the toolbar on the Draft workbench in order to use it, what I am unable to locate is the icon (or the workbench called "Draft") when I am in the customize toolbar window. It just doesn't seem to be visible (within the list from which you choose the icons from, which is selected using the pop-up menu immediately above it). If it were visible in the lefthand list then I could select it, click the arrow pointing to the right and copy it onto my custom toobar.
My goal here is to be able to add it to my custom toolbar which I can then have available in the workbenches I use frequently. So I would then have the Clone icon available within the Parts workbench - for example.
thanks
Dean
You misunderstood him. The Draft workbench is entirely written in Python and thus the internal group name of the command is called "Python". So, switch to the category "Python" on the left side then you'll find the Draft commands. Since this is a bit misleading we should make sure that (Python) commands are sorted by the workbench they belong to.I know where to find the icon within the toolbar on the Draft workbench in order to use it, what I am unable to locate is the icon (or the workbench called "Draft") when I am in the customize toolbar window. It just doesn't seem to be visible (within the list from which you choose the icons from, which is selected using the pop-up menu immediately above it). If it were visible in the lefthand list then I could select it, click the arrow pointing to the right and copy it onto my custom toobar.
Yes maybe, English is not my first langage.
But I understand you want Draft Clone tool button in Part Design workbench.
Is it ? I can explain more if needed.
