Export Dwg-Dxf
Export Dwg-Dxf
This morning i discovered this Freecad. Drawing system is great an easy. But export Dwg, Dxf is not working.
First problem: Cannot find Tiegha File Converter.
No problem. I installed it.
Now he don't give any message, but is not saving the file as well.
How can i export the Freecad Files to dwg, dax, of 3ds of Skp?
Many thanks. Hope someone can help me out.
Peter
Peter
Peter Kegels
Gambia Service Center (en.gscgambia.com - nl.gscgambia.com)
Card - Creative ARt and Design (Creative Architectural Rendering and Design)
Re: Export Dwg-Dxf
Hi Peter, Welcome to FreeCAD and the forum. Look for the mod's to move this thread to the Help section where it probably belongs. At the top of that section, The first thread, right below the NewTopic* button - IMPORTANT: Please read first before asking for help - should be read and followed.
Not knowing exactly what your trying to export, it is hard to say what might be happening, but I can give you some general information at this point. First, it might help to give a quick look at - FreeCAD and DWG Import (basically the same thing relates to export as well). DXF and DWG export 2G on the XY plane only.
I see you mention the SKP format. The best format to exchange data between FreeCAD and Sketchup is the DAE format. You'll need to have pyCollada for that.
Once this thread get's moved, and we can get your FreeCAD info as well as an example file your having problems with, we'll be in a much better position to help you directly and get you going.
Mark
Mark
Re: Export Dwg-Dxf
Thx for the info Mark.
Now i see that this post is posted on the wrong level.
To give you an answer on my system:
OS: Windows 7
Word size: 32-bit
Version: 0.14.3700 (Git)
Branch: releases/FreeCAD-0-14
Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
The export i need is for Chief Architect.
End i can create different files with one ore more sketches (Part Design). Not one is working for this export.
Many regards.
Peter
OS: Windows 7
Word size: 32-bit
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
Many regards.
Peter
Peter Kegels
Re: Export Dwg-Dxf
I tried this: https://github.com/yorikvanhavre/draft-dxf-importer
But this pad: C:\Users\yourUser\Application Data\FreeCAD is not existing on this windows. For that reason i created the FreeCAD file myself in: C:\Users\Peter\AppData\Local\FreeCAD
But that is not working.
Hope we can cover this problem.
Many regards.
Peter
Many regards.
Peter
Peter Kegels
Re: Export Dwg-Dxf
For me my macro folder ispeterkegels wrote:But this pad: C:\Users\yourUser\Application Data\FreeCAD is not existing on this windows. For that reason i created the FreeCAD file myself in: C:\Users\Peter\AppData\Local\FreeCAD
C:\Users\USERNAME\AppData\Roaming\FreeCAD
OS: Windows 7
Word size: 64-bit
Python version: 2.7.6
Qt version: 4.8.5
SoQt version: 1.6.0a
OCC version: 6.6.0
"fight the good fight"
Re: Export Dwg-Dxf - Now Stack Trace
Hey SgRoan,
Thx for the info.
So far so good.
Freecad is willing to do his job wright now. But he can't.
Message: Stack Trace: ----
Thx for the info.
So far so good.
Peter Kegels
Re: Export Dwg-Dxf
@peteerkegels
Please don't double post on the same issue. One of the moderators is sure to point this out to you.
Use this post as it already has your About FreeCAD info.
We need to get .dxf working first. FreeCAD uses the TeighaFileConverter to convert .dxf to .dwg internally.
Can you please post a screen shot of the contents of your macro directory to make sure that the required .py files are installed correctly. It should look something like this.
Also see here, if you haven't already: http://freecadweb.org/wiki/index.php?ti ... DWG_Import
Re: Export Dwg-Dxf
Hey sgrogan,
Thx for your support.
No idea how to get the print-screen in this forum.
But it is the same.
Only your macro test is not included in my list.
Path: ..\Peter\AppData\Roaming\FreeCAD
Many regards.
Hope we find the problem.
Wiki: You might need to set the path to the converter executable manually, in the menu Edit -> Preferences -> Draft -> Import/Export options. => I cannot find Draft in that pop up window.
But it is the same.
Many regards.
Peter Kegels
Re: Export Dwg-Dxf
To show a screen shot use the win7 snipping tools. It is usually in the start menu. If not, Start Menu > all programs > accessories > snipping tool
Save as a file (.png or .jpg) and upload as an attachment to the forum. I don't need the macro folder see below.
In FreeCAD goto View > Views > and check Report view and Python console.
Now export your circles as .dxf
Post a screen shot of your FreeCAD at this point.
Re: Export Dwg-Dxf
Hope this is ok?
Peter Kegels
