Repeating last command
Can I repeat the last command? I mean like in Rhino where you can select _Line once and for subsequent lines you simply press ENTER.
Re: Repeating last command
No, this is not possible in FreeCAD.
Ok, thanks. I am not using it too often anyway, but I was afraid of missing something.
hi welcome
Try this macro Macro_CloneConvert to make a copy or clone of a selected object
if you want a copy without modifcation just click OK as long as you want
mario
mario
I've been thinking about that too already... Werner, do you think there is a place where we could catch and save the name of commands being issued? Maybe in Gui/Command.cpp in Command:invoke()? Then it would be a piece of cake to add a new command that re-runs the stored command name... But I'm not really sure how/where to store that command name? Any suggestion?
Yorik, what about this idea:
Right-Clicking in the 3D-View would give you the "re-run last command"-command in the menu.
Or if you really want to place it in a FreeCAD-menu, the Edit-Menu in the top row is always present ...
Roland
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
Yes, once we have the last command saved somewhere, all this can be possible...r-frank wrote:Yorik, what about this idea:
Roland
But for real, this should be a keyboard shortcut (space, enter,...) there is already to much unnecessary clicking.
Getting the command name is easy but the problematic part are the prerequisites in order to run a command, e.g. the selection or commands like padding or pocketing.
The repeat command might be useful for creating new objects with no dependency to any other object but making all the other commands repeatable could lead to many problems.
Instead of having a repeat command the commands which a worth can be changed that way that they don't exit automatically but stay active as long as the user exits it manually.
+1 I've been advocating that for a long time.wmayer wrote:Instead of having a repeat command the commands which a worth can be changed that way that they don't exit automatically but stay active as long as the user exits it manually.
For example, issue #1518
