Issue binary operation
I have this cup-shape thing, created by rotating a closed wire (the thing is a solid), and then punching a hole through it by creating a cylinder that goes through it and making a cut with that.
When seen from the outside there appears to be a hole, but on the inside the cylinder is still there.
I've also cut a corner out of the thing, using a large cube, which does work. You can also see that the object is in fact a solid, it's not hollow inside.
This is part of a much larger project; all other parts removed, just the affected bit posted here.
Totally weird.
OS: Linux Mint 17 Qiana
Version: 0.15.4484 (Git)
Hash: f72c802f5daa378298ffbfc3f3a17ec2d35c1816
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.7.1
Totally weird.
Qt version: 4.8.6
OCC version: 6.7.1
- cut test.fcstd
- (54.9 KiB) Downloaded 39 times
- DeepSOIC
Re: Issue binary operation
Looks like a perfect bug. The only thing I wonder of is where is the thing that was revolved, in your file.
Interestingly, if I set the cylinder's angle to below 360 degree to get a pie, the cut works normally.
OS: Windows 8.1
Version: 0.15.4320 +24 (Git)
Branch: Eivind-Expressions,origin/OpticConstraints-shoogen2 ( excuse me for not using master)
Hash: ade893f35026d2c97ee8628135472bf31c2eafad
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
OS: Windows 8.1
Qt version: 4.8.6
OCC version: 6.7.1
It's got to do with the location of that specific cylinder.
Other cylinders cut holes as expected, as do cubes...
So weird.
So weird.
- cut test.fcstd
- (213.78 KiB) Downloaded 32 times
I created the revolved part in a second file (using a separate file for fiddling and creating more tricky parts and then copy/paste it into my main file).
Here again with the original wire used to create the part. It has been rotated 90° after rotation.
- cut test.fcstd
- (214.67 KiB) Downloaded 35 times
- DeepSOIC
I'm not able to reproduce the problem outside of your file. I think it may be important how did you create the cup.
EDIT: (added attachment)
- cup-cut-test.FCStd
- (18.72 KiB) Downloaded 37 times
- tanderson69
The problem was evident when I opened the file. I recalculated all the features and the problem went away. I am thinking this is specific to your version of occ. I have "OCC version: 6.8.0.oce-0.17-dev"
I just copied the original wire to my main file, there recreated the cup by revolving it, and now it all seems to work fine. So it may also be related to the missing wire. Nevertheless it's a bug.
There's a second object in my file that also has such issues, cuts that don't work. Also created in a separate file, copy/pasted into my main project file, where the link to the original wire has been lost.
Closely related buggy goodness.
Select Cut070, then subtract Extrude021.
Resulting image is a mess...
- cut test 2.fcstd
- (48.05 KiB) Downloaded 35 times
I can see the mess, but it disappears after a complete recompute.wvmarle wrote:Closely related buggy goodness.
OS: Debian GNU/Linux 7.8 (wheezy)
Version: 0.15.4486 +191 (Git)
Branch: yorik/path-module,bugfix-draftextrude,dev-dxfsplineimport
Hash: b0f9b63e1253903d291dadf2d66376aaab1b147c
Python version: 2.7.3
Qt version: 4.8.2
OCC version: 6.8.1.dev-6b0e8bd
How to do such a "complete recompute"?
