shoogen
Posts: 2823 Joined: Thu Dec 01, 2011 5:24 pm
Post
by shoogen » Fri Jan 16, 2015 4:26 pm
for obj in App.ActiveDocument.Objects: obj.touch()
wvmarle
Posts: 148 Joined: Fri Oct 17, 2014 8:09 am
Post
by wvmarle » Fri Jan 16, 2015 4:31 pm
What to do with that? I tried the Python Console but it gives a syntax error on the second line.
wvmarle
Post
by wvmarle » Fri Jan 16, 2015 4:33 pm
Closing and re-opening the file also doesn't make a difference.
wvmarle
Post
by wvmarle » Fri Jan 16, 2015 4:45 pm
How to install/run/use that macro?
wvmarle
Post
by wvmarle » Fri Jan 16, 2015 4:48 pm
Ah, got it, just found the howto link on that page. Seems to work indeed.
wvmarle
Post
by wvmarle » Fri Jan 16, 2015 5:35 pm
Works for one out of three similar objects
the other two get messed up just as badly, no luck recalculating. May post fragements tomorrow, very much time to go to sleep.
wvmarle
Post
by wvmarle » Sat Jan 17, 2015 7:25 am
Cut down to only the offending parts, and the mess remains.
Seems to be some kind of bug.
Part "high cup001" is a copy, that's why the original wire is not linked to the object. I copied this object "Wire" from the other file for reference.
I assume this is a bug in the system. Let me know if any additional info is needed for bug report.
cut test 4.fcstd
(10.32 KiB) Downloaded 23 times
quick61
Posts: 3803 Joined: Sat Aug 24, 2013 2:49 am
Post
by quick61 » Sat Jan 17, 2015 7:51 am
Humm... there seems to be some "unseen" problem with the extrude. I deleted and then remade it and the Cut is working as expected. Strange, but I've seen it happen before. Try doing the same and see what happens.
Here is the file -
Mark
OS: Kubuntu 14.04.1 LTS
Word size: 64-bit
Version: 0.14.3705 (Git)
Branch: releases/FreeCAD-0-14
Hash: f25e6e4716fb63ef3ac618ce9e552761bbc1b4b1
Python version: 2.7.6
Qt version: 4.8.6
SoQt version: 1.6.0a
OCC version: 6.7.1
This post made with 0.0% Micro$ oft products - GOT LINUX ?
wvmarle
Post
by wvmarle » Sat Jan 17, 2015 8:22 am
That's weird indeed.
I used the same wire to create the same extrude three times. One time was the previous mention; where after a recalculate it went fine. The second and third extrudes include the one that I posted.
Sounds like a bug to me. Will be hard to track that one down as it doesn't seem to be easily reproducible.
