OS: Windows
Word size: 32-bit
Version: 0.14.3700 (Git)
Branch: releases/FreeCAD-0-14
Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
New to this so apologies if the answer to this is blatantly obvious.
I have created a simple 3d model in Freecad and created a drawing with one of the standard A4 templates. However in the "drawing" tab none of the lines from the template appear and hence when I print from here none of them appear in the print.
All the lines do appear however when I use the "Open a selected page in the browser view" button, bit I cannot print from this tab as the print option is then greyed out.
Thanks in advance.
Cheers
Ian
Printing Drawings
Re: Printing Drawings
Hello Ian, Welcome to FreeCAD and the forum. Thank you for posting your FreeCAD info. With that, I will first suggest that you grab one of the recent development snapshots. There have been a lot of bug fixes, including several related to Drawings, along with the ability to use a new plugin workbench that is a BIG help with dimensions. You can find the most recent development snapshots here - http://sourceforge.net/projects/free-ca ... velopment/ - These do not install, you simply unzip it into a directory and run the executable from the /bin folder.crofti67 wrote:OS: Windows
Word size: 32-bit
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
Thanks in advance.
Cheers
Ian
Now to your problem. When you say you created a drawing, just how did you do that? There are several ways. Have you tried another template?
Mark
Thanks Mark
I used the A4 button as shown in the attached screenshot whilst in the drawing workbench.
Then I selected my "fusion" part and hit the "Insert an orthographic projection......" button to populate the drawing.
I will download the latest version as you suggest to begin with and see if that improves matters.
Cheers
Ian
Cheers
Ian
- Capture1.PNG (11.27 KiB) Viewed 1322 times
Mark
Using the latest version as you suggested has worked a treat, it is coming up with some spurious errors but generally it is responding much better to changing the templates and showing all the lines in both drawing view and web style view.
That has fixed this issue for me.
Thanks again.
Ian
Thanks again.
Ian
Your welcome, and now that you have a 0.15 development version, you can also now use the FreeCAD_drawing_dimensioning plugin Workbench that hamish has so nicely done. It is a real pleasure to use and makes adding dimensions to your drawing a snap. There is a thread in the Developers corner section of the forum on the workbench - Drawing dimensioning workbench for FreeCAD v0.15 - and might be worth a quick look through to understand who it works. Read the "README.md" for how to install it.crofti67 wrote:Mark
Thanks again.
Ian
Mark
