thread bolt
thread bolt
hi, I need to draw a bolt and its thread; I have using FreeCad for the first time, and also I haven't more experience with CAD software. I have made head and body of bolt, but I have problem in drawing thread. Do you now the best way to make that? I should use many circles? intersect with plane object? Help!
Re: thread bolt
Sorry, with the current version this not possible. Within the next weeks we'll release a new version. I hope to add a function like that until then.
Re: thread bolt
Oh, right! thank you very much! Also if I will use script engine instead of gui, I will try it.... I don't not python, but I think it's similar to other script languages like php, perl ecc.
Bye!
Bye!
Re: thread bolt
aehm.... I don't not python = I don't know python .....
Re: thread bolt
oh, if you're strong-willed to use Python then you could have a look on www.pythonocc.org This offers a Python binding for the (almost) whole OpenCascade library. At http://svn.gna.org/viewcvs/pythonocc/tr ... iew=markup you'll find an example for creation of a bottle with thread.
Maybe this helps you to get it working for your needs. But note, pythonOCC uses OpenCascade 6.3.0 while the current FreeCAD release is based on OpenCascade 6.2.3. Thus, it's at the moment not possible to use both together. With the next FreeCAD release we will fix this issue.
Cheers,
Werner
Cheers,
Werner
