FEM - praktyczne użycie w Fedora 22
Polish forum
Moderator: PrzemoF
Regulamin forum i pomocne informacje
WAŻNE! Przeczytaj zanim poprosisz o pomoc
PrzemoF
Re: FEM - praktyczne użycie w Fedora 22
Postby PrzemoF » Tue Dec 01, 2015 4:19 pm
[przemo@localhost freecad]$ sudo dnf -v provides freecad
cachedir: /var/cache/dnf
Loaded plugins: copr, playground, protected_packages, system-upgrade, download, generate_completion_cache, repograph, needs-restarting, noroot, reposync, config-manager, kickstart, builddep, Query, migrate, debuginfo-install
DNF version: 1.1.1
repo: using cache for: updates-testing-source
not found deltainfo for: Fedora 22 - Test Updates Source
repo: using cache for: przemof-FreeCAD
not found deltainfo for: Copr repo for FreeCAD owned by przemof
not found updateinfo for: Copr repo for FreeCAD owned by przemof
repo: using cache for: fedora
not found deltainfo for: Fedora 22 - x86_64
not found updateinfo for: Fedora 22 - x86_64
repo: using cache for: rpmfusion-free-updates
not found deltainfo for: RPM Fusion for Fedora 22 - Free - Updates
not found updateinfo for: RPM Fusion for Fedora 22 - Free - Updates
repo: using cache for: fedora-source
not found deltainfo for: Fedora 22 - Source
not found updateinfo for: Fedora 22 - Source
updates-testing-source: using metadata from Sun Nov 29 22:12:27 2015.
przemof-FreeCAD: using metadata from Mon Nov 30 20:35:41 2015.
fedora: using metadata from Sat May 23 11:23:20 2015.
rpmfusion-free-updates: using metadata from Mon Nov  2 18:07:50 2015.
rpmfusion-free: using metadata from Wed Aug  5 13:49:43 2015.
updates: using metadata from Mon Nov 30 23:04:17 2015.
fedora-source: using metadata from Sat May 23 10:15:57 2015.
Last metadata expiration check performed 0:00:14 ago on Tue Dec  1 16:15:28 2015.
Searching Packages:
freecad-1:0.16-git_5858_8dd2140_031115.x86_64 : A general purpose 3D CAD modeler
Repo        : @System
freecad-1:0.16_pre-5996.x86_64 : A general purpose 3D CAD modeler
Repo        : przemof-FreeCAD
freecad-0.15-1.fc22.x86_64 : A general purpose 3D CAD modeler
Repo        : fedora
freecad-1:0.15-5.fc22.x86_64 : A general purpose 3D CAD modeler
Repo        : updates
Może spróbuj disable/enable (albo remove/enable)?
sudo dnf copr disable przemof/FreeCAD
sudo dnf copr enable przemof/FreeCAD
ChrisTom
Postby ChrisTom » Tue Dec 01, 2015 8:19 pm
Rzuć okiem na poniższe:
~]$ dnf copr list przemof
========================================== List of przemof coprs ===========================================
przemof/FreeCAD : Unofficial FreeCAD builds
~]$ dnf copr search freecad
============================================= Matched: freecad =============================================
hobbes1069/FreeCAD : FreeCAD Repository for EPEL 7
                   : This requires replacement of some system libraries, YMMV.
loveshack/livhpc : Various things used on the Liverpool University HPC service that aren't yet, or can't be
                 : (e.g. using dkms), in Fedora/EPEL, as well as rebuilds and modifications of existing
                 : packages.  This targets principally EPEL6 -- other targets are currently mostly for
                 : testing the packaging.  See also the parallel gridengine and orangefs repos.
                 : Not in Fedora (some not suitable):
                 : FIRESTARTER, GBRV, R-Rmpi, R-pbdBASE, R-pbdDEMO, R-pbdDMAT, R-pbdMPI, R-pbdNCDF4,
                 : R-pbdSLAP, R-pmclust, adept-utils, autodock_vina, blcr, bowtie2, callpath, code_saturne,
                 : cryptominisat2, darshan, datamash, dimemas, extrae, feast, flom, gti, hpcc, harminv,
                 : hbdict, hypre, ior, ipm, jcuber, knem, launchmon, libctl, libeatmydata, libhmsbeagle,
                 : libmonitor, libmxml, libomp_oss, libopensmskummeeplugin, libsprng2, libtinythread++,
                 : lighter, m4ri, mdhim, mdtest, mpiP, mrbayes, mrmpi, mrnet, must, muster, n-diff, oases,
                 : octopus, open-axiom, openblas-compat (subvert netlib, atlas), openfoam, openspeedshop,
                 : openturns (from upstream srpm), opium, otf2prv, padb, paraver, perl-Algorithm-Munkres,
                 : perl-Bio-Phylo, perl-BioPerl, perl-BioPerl-Run, perl-XML-XML2JSON, petsc, phish, phyml,
                 : plfs, plink, ploticus, pnmpi, procenv, quantum-espresso, RASPA, ravel, sionlib, tophat,
                 : txr, velvet, warewulf-nhc, zoltan
                 : Rebuilds/ports for EPEL6:
                 : CGAL, OCE, R-rlecuyer, cp2k, engrid, freefem++, freecad, gmm, gromacs,
                 : hpl, iotop, jsoncpp, lapack, munge, netgen-mesher, perl-Ace, perl-Convert-Binary-C,
                 : perl-Data-Stag, perl-Math-Derivative, perl-Math-Spline, perl-PostScript, perl-SVG-Graph,
                 : rpmlint, smesh, suitesparse, sundials
                 : Adaptations/updates for EPEL6:
                 : NetPIPE (for mpi), cgnslib (update, Fortran support), compat-blacs (for
                 : compat-scalapack), compat-scalapack (version 1), dmtcp (update), elpa (update), fftw
                 : (update), gromacs (update), libdb48, ncbi-blast+ (update), net-snmp (extension support),
                 : netcdf (parallel build), openblas (against updated lapack and with AVX2), opensm
                 : (update), samtools (update)
                 : Now in EPEL: MUMPS (scotch ordering), dl_poly, cube update, scorep update, scalasca,
                 : dssp
maarten79/FreeCad : No description given.
PrzemoF
Postby PrzemoF » Tue Dec 01, 2015 8:49 pm
Wygląda to tak jak powinno (chyba)?
Edit: Nadal nie wiem czy działa aktualizacja
ChrisTom
Postby ChrisTom » Tue Dec 01, 2015 9:03 pm
Również odnoszę wrażenie, że wygląda to tak jak powinno, ale ciągle nie listuje pakietu (pakietów) z Twojego repozytorium u mnie. Może to wina F23 albo wersji dnf (1.1.1 vs 1.1.4)?
PrzemoF
Postby PrzemoF » Tue Dec 01, 2015 9:25 pm
A jak próbujesz zainstalować "sudo dnf install freecad" to co się dzieje?
$ sudo dnf install freecad
Ostatnio sprawdzono ważność metadanych 2:01:08 temu w dniu Tue Dec  1 19:24:07 2015.
Rozwiązano zależności.
 Pakiet                               Arch.                        Wersja                                Repozytorium                          Rozmiar
Instalowanie:
 freecad                              x86_64                       1:0.16_pre-5996                       przemof-FreeCAD                        18 M
 freecad-data                         noarch                       1:0.16_pre-5996                       przemof-FreeCAD                        68 M
 python-collada                       noarch                       0.4-7.fc22                            fedora                                172 k
Podsumowanie transakcji
Instalacja  3 Packages
Całkowity rozmiar pobierania: 87 M
Rozmiar po zainstalowaniu: 166 M
i jeszcze "sudo dnf repolist" oraz "sudo dnf repository-packages przemof-FreeCAD list all"
$ sudo dnf repolist
Ostatnio sprawdzono ważność metadanych 2:06:28 temu w dniu Tue Dec  1 19:24:07 2015.
identyfikator repozytorium                                      nazwa repozytorium                                                              stan
*fedora                                                         Fedora 22 - x86_64                                                              44762
home_Horst3180                                                  Horst3180's Home Project (Fedora_22)                                                8
przemof-FreeCAD                                                 Copr repo for FreeCAD owned by przemof                                              4
rpmfusion-free                                                  RPM Fusion for Fedora 22 - Free                                                   500
rpmfusion-free-updates                                          RPM Fusion for Fedora 22 - Free - Updates                                          87
*updates                                                        Fedora 22 - x86_64 - Updates                                                    16847
fedora:/home/przemo/rpmbuild
$ sudo dnf repository-packages przemof-FreeCAD list all
Ostatnio sprawdzono ważność metadanych 2:06:32 temu w dniu Tue Dec  1 19:24:07 2015.
Zainstalowane pakiety
freecad.x86_64                                                         1:0.16_pre-5996                                               @przemof-FreeCAD
freecad-data.noarch                                                    1:0.16_pre-5996                                               @przemof-FreeCAD
Dostępne pakiety
freecad.src                                                            1:0.16_pre-5996                                               przemof-FreeCAD
freecad-debuginfo.x86_64
PrzemoF
Postby PrzemoF » Tue Dec 01, 2015 10:15 pm
Wymuszenie przedawnienia pamięci podręcznej (cache expire) pomaga:
sudo dnf --refresh repository-packages przemof-FreeCAD upgrade freecad
ChrisTom
Postby ChrisTom » Tue Dec 01, 2015 10:18 pm
Nie wiem dlaczego, ale w tej chwili jest ok ;)
[@~]$ sudo dnf install freecad
Ostatnio sprawdzono ważność metadanych 0:32:29 temu w dniu Tue Dec  1 22:41:48 2015.
 Package                              Arch.          Wersja                   Repoz.                  Rozm.
Instalowanie:
 agg                                  x86_64         2.5-23.fc23              fedora                  147 k
 freecad                              x86_64         1:0.16_pre-5997          przemof-FreeCAD          18 M
 freecad-data                         noarch         1:0.16_pre-5997          przemof-FreeCAD          68 M
 pyparsing                            noarch         2.0.3-2.fc23             fedora                  103 k
 python-collada                       noarch         0.4-9.fc23               fedora                  172 k
 python-matplotlib                    x86_64         1.4.3-6.fc23             fedora                   35 M
 python-matplotlib-data               noarch         1.4.3-6.fc23             fedora                  2.3 M
 python-matplotlib-data-fonts         noarch         1.4.3-6.fc23             fedora                  991 k
 python-matplotlib-tk                 x86_64         1.4.3-6.fc23             fedora                   79 k
 qhull                                x86_64         2003.1-26.fc23           fedora                  358 k
 stix-math-fonts                      noarch         1.1.0-8.fc23             fedora                  291 k
 tkinter                              x86_64         2.7.10-8.fc23            fedora                  382 k
Instalacja  12 Packages
Całkowity rozmiar pobierania: 126 M
Rozmiar po zainstalowaniu: 241 M
Dzięki
PrzemoF
Postby PrzemoF » Tue Dec 01, 2015 10:24 pm
No 90% musiał się cache przedawnić. Njaważniejsze, że działa :-)
