to convert stl files into surface and then to work on that file
Post here if you have a FreeCAD-related job to offer to the FreeCAD community. This can include programming or modeling.
divyank.d.jain
Postby divyank.d.jain » Wed Jun 08, 2016 10:07 am
please let me know how much do u charge if i have some files which i need to convert them into 3dm format.
I want a 100% replica of the stl format. No modifications made. Length X Width X Height = 135mm x 147mm x 73mm
Please find the image attached for the same
REPLY ASAP
my number is +91 9887713033
divyank.d.jain@gmail.com
Last edited by divyank.d.jain on Thu Jun 09, 2016 7:10 am, edited 1 time in total.
Jee-Bee
Re: to convert stl files into 3dm format
Postby Jee-Bee » Wed Jun 08, 2016 2:26 pm
If you want to make from an stl file an 3dm file... i would say not possible. Even rhino where you show youre pictures from can't do that. at least not in rhino 4. Simply because a mesh file isn't parametric.
As far aas i know Freecad don't have 3dm capabilties at this moment. so if you want try it find somebody with rhino self and try to apply a surfaces over the model!!
divyank.d.jain
Postby divyank.d.jain » Thu Jun 09, 2016 7:04 am
ok... Lets not go for stl to 3dm
but is there any other software or way where in I can convert these files to surface structure and give them proper thickness and if i need to remove any thing can tell anybody to do that accordingly..
please let me know
thanks
jeno
Postby jeno » Sat Jun 18, 2016 11:29 am
divyank.d.jain wrote:please let me know how much do u charge if i have some files which i need to convert them into 3dm format.
REPLY ASAP
Maybe this piece of software could help. It imports stl and exports 3dm. They offer a 2 day evaluation version. Could be sufficient for you.
divyank.d.jain
Postby divyank.d.jain » Sat Jun 18, 2016 1:22 pm
Thanks Jeno, will try and will let you know...
jeno wrote:Maybe this piece of software could help. It imports stl and exports 3dm. They offer a 2 day evaluation version. Could be sufficient for you.
