Assembly Workbench icons aligned to guidelines
A subforum for research and development of the user interface of FreeCAD
Moderator: agryson
agryson
Re: Assembly Workbench icons aligned to guidelines
Postby agryson » Sun Mar 19, 2017 9:19 pm
triplus
Postby triplus » Mon Mar 20, 2017 1:02 am
agryson wrote:Done.
Thanks for the tip on implementation @triplus
This can now be in the pull request. (tested sucessfully on local)
AssemblyWorkbench.svg
You're welcome. I guess what we now need is a bit more useful Assembly workbench. ;)
P.S. Or maybe after you finish all the work you might give it a shot at aligning Assembly 2 workbench icons. As that is more or less what FreeCAD users have been using in the past years when it comes to Assembly capabilities. Note that this is just an idea and feel free to disregard it.
agryson
Postby agryson » Mon Mar 20, 2017 5:57 am
triplus wrote:maybe after you finish all the work you might give it a shot at aligning Assembly 2 workbench icons. As that is more or less what FreeCAD users have been using in the past years
sounds good, and I'm sure that many of the icons could be reused between the two during development of FreeCAD Assembly. added to the list
