If we set the factor back to 1 then Qt will calculate the page size (among other things) incorrectly and your 200 mm bar will go back to being 203.2 mm( http://www.forum.freecadweb.org/viewtop ... 35&t=21597 ). I don't see a way around it right now.HoWil wrote:Is it possible to switch the factor 10 scale off when exporting.
Problem with the scale of views made with the draftview command
- wandererfan
Re: Problem with the scale of views made with the draftview command
Sorry, I misunderstood the discussion before.
I thought it is possible to scale single views and not the complete document.
But looks like the discussion is still about the document.
BR,
HoWil
BR,
HoWil
- wandererfan
The single views are scaled up by X before they are added to the drawing. If this isn't done, the view is rendered in 1/X scale on the page and you'll get tiny views on a regular size page. I don't think unscaling the individual view solves your problem.HoWil wrote:I thought it is possible to scale single views and not the complete document.
