Problem with the scale of views made with the draftview command
There is a problem with the scale of views made with the draftview command. The views are 10 times bigger than they should have been.
From what I was able to test only happens with the views made with the draftview and Archview commands, the views made with the DrawViewPart command are in the right scale.
greetings,
Renato Rebelo
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10802 (Git)
Build type: None
Hash: 10ce910c03347a90712327a7cc7be2bcdee13afc
Python version: 2.7.12
OCC version: 7.1.0
greetings,
Renato Rebelo
Build type: None
OCC version: 7.1.0
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
- microelly2
Re: Problem with the scale of views made with the draftview command
There is a default scale value HintScale=10.0 in the page object
set this back to 1 should work
- bp_460.png (11.39 KiB) Viewed 3070 times
Indeed, I see the problem too, that's strange... The transform (position, rotation, scaling) is done by techdraw itself, not sure what has changed there... rotation and positionning still work correctly. But I couldn't really find where that 10x scaling happens.
Any idea @wandererfan? Could it be something to do with DPI stuff? There is this note in QGIViewSymbol.cpp
But it doesn't seem to be used anywhere...
//note: svg's are overscaled by (72 pixels(pts actually) /in)*(1 in/25.4 mm) = 2.834645669 (could be 96/25.4(CSS)? 110/25.4?)
//due to 1 sceneUnit (1mm) = 1 pixel for some QtSvg functions
- wandererfan
January update: https://www.forum.freecadweb.org/viewto ... =9&t=20385
You can turn HiRez off, but that will bring it's own problems - poor quality imported images and wrong size SVG exports among others.High Resolution - the resolution of drawings has been increased, in some cases as much as 10x. This will impact users of DrawViewImage, providing much higher quality results.
It will also affect users of DrawViewDraft and DrawViewArch. The higher resolution will mean that scales and perhaps positions will need to be modified. Existing drawings may need views repositioned.
Too much info on this forum, you always loose something
We could counter the problem by embedding the svg code in a transform node in Draft and Arch views, and therefore add an extra scaling, that's easy.
Is there a way to know how much extra scaling I should add?
- wandererfan
#include <Mod/TechDraw/Gui/Rez.h>yorik wrote:Is there a way to know how much extra scaling I should add?
double factor = Rez::getRezFactor();
double guisize = Rez::guiX(someAppNumber); //mm to QGraphicsScene units
double appsize = Rez::appX(someGuiNumber); //QGraphicsScene units to mm
Overloads for Base::Vector3d, Base::Vector2d, QPointF, QSize, QRectF.
No Python version yet.
Okay that should do it, I can use that inside the cpp code of ArchView and DraftView.wandererfan wrote:#include <Mod/TechDraw/Gui/Rez.h>
Thanks!
*EDIT*
double factor = Rez::getRezFactor(); doesn't seem to work when called from an App object (besides it is probably wrong to use Gui stuff in App)... Any idea of a workaround? Or maybe it is in the Gui side that the extra scaling should happen? In QGIViewSymbol::drawSvg() maybe?
**EDIT 2** Done in git commit 17b597fb6
- wandererfan
Or maybe it is in the Gui side that the extra scaling should happen? In QGIViewSymbol::drawSvg() maybe?yorik wrote:
**EDIT 2** Done in git commit 17b597fb6[/quote]
Great thanks!. The scaling is only done on the Gui side since it is basically a hack to get some QGraphicsScene functions to behave as if they understand floating point numbers.
It's OK now
Thank you both,
Renato Rebelo
Thank you both,
Renato Rebelo
Is it possible to switch the factor 10 scale off when exporting. This would resolve this prob:
https://forum.freecadweb.org/viewtopic. ... 7&start=30
Quickly tested it on the following system and still see a factor x10 in the view(-box) in Inkscape:
Version: 0.17.10909 (Git)
Build type: None
Hash: eb5c56b50297a03b275846c7bb064ad4aae094da
OCC version: 7.1.0
BR,
HoWil
Build type: None
OCC version: 7.1.0
BR,
HoWil
