First test drive ...
Hi there.
Just tried Techdraw.
Using FreeCAD 0.17.10807 on Windows 7 - 64 bit.
Using Blender Navigation Style.
> Insert new default drawing page
> clicking on the green dot near the "Designed by" brings up the Editable field to insert Creators name
> after clicking "OK" changes are applied
> no matter where i click now, the same editable field is brought up again ... Bug ?
> even right-ckling is bringing up the Editor-Editable-Field again ...
> clicking on insert new view will insert new view but also "glue" the drawing page to the cursor
> wherever i move the cursor, the page follows, no chance to detach the drawing
These things stopped me from testing further ...
Help would be appreciated.
Thanks for all efforts done up to now.
Roland
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
- wandererfan
Re: First test drive ...
I can't duplicate any of that on:
OS: Ubuntu 12.04.5 LTS
Version: 0.17.10698 (Git)
Build type: debug
Hash: ac2f9f8902b67143ea081fedc9ffed86fc1a1bd3
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
OCC version: 7.1.0
with "touchpad" or "blender" styles.
I don't know much about navigation styles. Do you get the same behaviour with another style?
Build type: debug
Qt version: 4.8.1
Coin version: 3.1.3
OCC version: 7.1.0
Yes, i just tried with OpenCasCade and CAD and Inventor Style.
The field which green dot i first click gets re-activated on every left- or right-click.
OS: Windows 7
Version: 0.17.10807 (Git)
Hash: b32e9806e1b075c745c0c9692e81aea1dcab81e4
Python version: 2.7.8
OCC version: 7.0.0
[I just noticed you have different (older) Qt and Coin versions ... Maybe that is the culprit ?]
Uh oh ...
I just verified with my Linux Mint-Installation.
OS: Linux Mint 17.3 Rosa
Build type: None
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
There everything works fine ...
OS: Windows 7
OCC version: 7.0.0
Uh oh ...
Build type: None
Qt version: 4.8.6
OCC version: 7.1.0
I can confirm a problem on Win and not on Ubuntu.r-frank wrote: Uh oh ...
What is the significance of the Page Result property?
The key to reproduce seems to be editing the editable fields when no views are on the page. After adding a view, closing and opening the drawing viewer fixes the problem.
A file like this is created at this time "A4_LandscapeTD1.svg.6bcf4dc0-378f-4c77-9cc9-f944ccaee72a" before this only a file like "A4_LandscapeTD.svg" exists in the C:\Users\Chris\AppData\Local\Temp\FreeCAD_Doc_(+ some hash) sub-directory.
"fight the good fight"
- wandererfan
Template is "PropertyFile" containing full path to original template on original machine.sgrogan wrote:What is the significance of the Page Result property?
PageResult is "PropertyFileIncluded" containing current state modified copy of original template.
On document restore, Template is ignored and PageResult is used instead since restore machine may not have a copy of the original template in the original location.
I don't know why that would have any effect on mouse clicks. Maybe the dialog is not getting destroyed properly on Win?
- wandererfan
Coin shouldn't be involved, but Qt might be. I'll try on a different machine.r-frank wrote:I just noticed you have different (older) Qt and Coin versions ... Maybe that is the culprit ?
Xenial uses QT4 4.8.7, same as win. If there is no problem on linux then it may be a win libpack/packaging (I upgraded QT in the libpack). If someone can verify that 4.8.7 works on linux, I can test linking FreeCAD against an older QT packaged by Peterl94 on Win to rule in/out a packaging issue.wandererfan wrote: Coin shouldn't be involved, but Qt might be. I'll try on a different machine.
- wandererfan
Seems to be fine with these two.sgrogan wrote: If someone can verify that 4.8.7 works on linux
FreeCAD daily
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10887 (Git)
Build type: None
Hash: 67fc70dadae471cb3d77dcf5562b4a86ec79f95d
Python version: 2.7.12
OCC version: 7.1.0
Local build
Version: 0.17.10661 (Git)
Build type: debug
Hash: 3b6020cda8fb91b3de33cf812975f1bd2f29cac1
OCC version: 7.1.0
I've started configuring a Win7 build environment, but I'll be overjoyed if I don't have to finish it!
Hold off for now.wandererfan wrote: I've started configuring a Win7 build environment, but I'll be overjoyed if I don't have to finish it!
Tomorrow I should have time to link against the older QT.
EDIT: Same behavior on
OS: Windows 7
Version: 0.17.10894 (Git)
Hash: 6e5bba3999b49098cac93482a13afca243a89d04
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
and
OS: Windows 7
Version: 0.17.10700 (Git)
Branch: py3-25
Hash: 79ecc1689ee4888341425dda3312acdf99b85742
Python version: 3.5.3
OCC version: 7.0.0
wandererfan - sorry about the slow response! The bug described by r-frank in the OP exists on MacOS with Qt5.6:
(CAD navigation style)
OS: Mac OS X
Version: 0.17.10934 (Git)
Build type: Debug
Hash: 4a51171593f0d69151308d9c0babb95e4e4b24f7
Python version: 2.7.13
Qt version: 5.6.2
OCC version: 7.1.0
OS: Mac OS X
Build type: Debug
Qt version: 5.6.2
OCC version: 7.1.0
