Illegal storage access...
Re: Illegal storage access...
g++ test.cpp -I/opt/opencascade-6.3/ros/inc -L/opt/opencascade-6.3/ros/lin/lib64 -D_OCC64 -lTKPShape -lTKFillet
/opt/opencascade-6.3/ros/Linux/lib64/libTKernel.so.0: undefined reference to `dlclose'
/opt/opencascade-6.3/ros/Linux/lib64/libTKernel.so.0: undefined reference to `dlsym'
/opt/opencascade-6.3/ros/Linux/lib64/libTKernel.so.0: undefined reference to `dlopen'
/opt/opencascade-6.3/ros/Linux/lib64/libTKernel.so.0: undefined reference to `dlerror'
collect2: ld returned 1 exit status
does this with or without OCC64
Then try:
g++ test.cpp -I/opt/opencascade-6.3/ros/inc -L/opt/opencascade-6.3/ros/lin/lib64 -D_OCC64 -lTKPShape -lTKFillet -lTKernel -ldl
For me the test app compiles fine (debian 64bits)
./a.out
Polyline is null
Polyline is null
Polyline is null
Polyline is null
Not sure what it means that this works, but FreeCAD fails.
Polyline is null
Polyline is null
Polyline is null
Polyline is null
I also tried without -D_OCC64, and got a segfault
Here is the last part of the strace output:
open("/opt/opencascade-6.3/ros/Linux/lib64/libTKGeomAlgo.so.0", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\3601\16\0\0\0\0\0@"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=4947008, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fefd557b000
mmap(NULL, 9383296, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fefd0a9d000
mprotect(0x7fefd0f45000, 2093056, PROT_NONE) = 0
mmap(0x7fefd1144000, 69632, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4a7000) = 0x7fefd1144000
mmap(0x7fefd1155000, 2338176, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fefd1155000
close(3) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fefd557a000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fefd5579000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fefd5578000
arch_prctl(ARCH_SET_FS, 0x7fefd5578700) = 0
mprotect(0x7fefd1144000, 36864, PROT_READ) = 0
mprotect(0x7fefd15e2000, 8192, PROT_READ) = 0
mprotect(0x7fefd19a1000, 20480, PROT_READ) = 0
mprotect(0x7fefd1eee000, 24576, PROT_READ) = 0
mprotect(0x7fefd2118000, 4096, PROT_READ) = 0
mprotect(0x7fefd238d000, 12288, PROT_READ) = 0
mprotect(0x7fefd29a0000, 24576, PROT_READ) = 0
mprotect(0x7fefd2cd1000, 12288, PROT_READ) = 0
mprotect(0x7fefd30f1000, 20480, PROT_READ) = 0
mprotect(0x7fefd345f000, 16384, PROT_READ) = 0
mprotect(0x7fefd3777000, 24576, PROT_READ) = 0
mprotect(0x7fefd3a49000, 20480, PROT_READ) = 0
mprotect(0x7fefd3dc2000, 16384, PROT_READ) = 0
mprotect(0x7fefd3fe1000, 4096, PROT_READ) = 0
mprotect(0x7fefd4266000, 4096, PROT_READ) = 0
mprotect(0x7fefd4557000, 28672, PROT_READ) = 0
mprotect(0x7fefd4775000, 4096, PROT_READ) = 0
mprotect(0x7fefd4bb7000, 40960, PROT_READ) = 0
mprotect(0x7fefd4ffc000, 20480, PROT_READ) = 0
mprotect(0x7fefd5352000, 36864, PROT_READ) = 0
mprotect(0x604000, 4096, PROT_READ) = 0
mprotect(0x7fefd5585000, 4096, PROT_READ) = 0
set_tid_address(0x7fefd55787d0) = 25962
set_robust_list(0x7fefd55787e0, 0x18) = 0
futex(0x7fffdd583c1c, FUTEX_WAKE_PRIVATE, 1) = 0
futex(0x7fffdd583c1c, 0x189 /* FUTEX_??? */, 1, NULL, 7fefd5578700) = -1 EAGAIN (Resource temporarily unavailable)
rt_sigaction(SIGRTMIN, {0x7fefd1f06790, [], SA_RESTORER|SA_SIGINFO, 0x7fefd1f107d0}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x7fefd1f06820, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7fefd1f107d0}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
futex(0x7fefd4560ac8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
brk(0) = 0x1629000
brk(0x164a000) = 0x164a000
open("/dev/zero", O_RDWR) = 3
mmap(0x20000000, 4096000, PROT_READ|PROT_WRITE, MAP_PRIVATE, 3, 0) = 0x20000000
brk(0x166d000) = 0x166d000
brk(0x168f000) = 0x168f000
brk(0x16b2000) = 0x16b2000
brk(0x16d5000) = 0x16d5000
brk(0x16f7000) = 0x16f7000
brk(0x171a000) = 0x171a000
brk(0x173b000) = 0x173b000
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
+++ killed by SIGSEGV +++
close(3) = 0
brk(0) = 0x1629000
Then try:
#include "config.h"
#include <TopoDS.hxx>
#include <TopoDS_Shape.hxx>
#include <TopoDS_Edge.hxx>
#include <Geom_Plane.hxx>
#include <Handle_Geom_Plane.hxx>
#include <BRep_Tool.hxx>
#include <BRepMesh.hxx>
#include <BRepBuilderAPI_MakeFace.hxx>
#include <BRepPrimAPI_MakeCylinder.hxx>
#include <Poly_Polygon3D.hxx>
#include <Handle_Poly_Polygon3D.hxx>
#include <TopExp_Explorer.hxx>
#include <gp_Ax2.hxx>
#include <gp_Pnt.hxx>
#include <gp_Dir.hxx>
#include <gp_Trsf.hxx>
#include <iostream>
int main(int argc, char** argv)
gp_Pnt p(0,0,0);
gp_Dir d(0,0,1);
double radius=1.0, height=4.0, angle=2.0*Standard_PI;
BRepPrimAPI_MakeCylinder mkCyl(gp_Ax2(p,d),radius, height, angle);
TopoDS_Shape Face = mkCyl.Shape();
BRepMesh::Mesh(Face,0.1);
// go through all edges
TopExp_Explorer ex;
for (ex.Init(Face, TopAbs_EDGE); ex.More(); ex.Next()) {
const TopoDS_Edge& aEdge = TopoDS::Edge(ex.Current());
gp_Trsf myTransf;
TopLoc_Location aLoc;
Handle(Poly_Polygon3D) aPoly = BRep_Tool::Polygon3D(aEdge, aLoc);
if (!aPoly.IsNull()) {
Standard_Integer nbNodesInFace = aPoly->NbNodes();
std::cout << nbNodesInFace << " nodes found" << std::endl;
else {
std::cout << "Polyline is null" << std::endl;
g++ test.cpp -I/opt/opencascade-6.3/ros/inc -L/opt/opencascade-6.3/ros/lin/lib64 -D_OCC64 -lTKPShape -lTKFillet -lTKernel -ldl -lTKPrim
#include "config.h"
#include <iostream>
gp_Pnt p(0,0,0);
gp_Dir d(0,0,1);
TopExp_Explorer ex;
gp_Trsf myTransf;
else {
is there an IRC channel for FreeCAD?
# g++ test.cpp -I/opt/opencascade-6.3/ros/inc -L/opt/opencascade-6.3/ros/lin/lib64 -D_OCC64 -lTKPShape -lTKFillet -lTKernel -ldl -lTKPrim
/tmp/ccW6GWry.o: In function `main':
test.cpp:(.text+0x18a): undefined reference to `BRepMesh::Mesh(TopoDS_Shape const&, double)'
Sorry this is so much trouble, but I hope this may help others, too.
Cheers,
PH
Cheers,
PH
Sorry, there is no IRC channel for FreeCAD.
Then try:
g++ test.cpp -I/opt/opencascade-6.3/ros/inc -L/opt/opencascade-6.3/ros/lin/lib64 -D_OCC64 -lTKPShape -lTKFillet -lTKernel -ldl -lTKPrim -lTKMesh
The problem with the thousands of OCC classes which library must be used to link with. I really hope that this reproduces the problem now...
Then try:
Polyline is null
Polyline is null
Polyline is null
Polyline is null
Polyline is null
Polyline is null
Polyline is null
Polyline is null
Polyline is null
Polyline is null
Polyline is null
And do you get the same result when not using the _OCC64 flag?
g++ test.cpp -I/opt/opencascade-6.3/ros/inc -L/opt/opencascade-6.3/ros/lin/lib64 -lTKPShape -lTKFillet -lTKernel -ldl -lTKPrim -lTKMesh
The test application bascially does the same as FreeCAD does when creating a shape.
