I will later reference the links to various other threads.
What are the required packages to be installed for FreeCAD, not a wish list, but what is required to compile and run
FreeCAD on Ubuntu.
What are the minimum dependenies for FreeCAD
"fight the good fight"
Re: What are the minimum dependenies for FreeCAD
I wish you had used the topic I linked rather than create yet a new one...
Edit: this topic Current state of FreeCAD's Dependencies
Thanks Norm, If a mod can move it great..
drei's questions go unanswered.I know Python 2.7, but which packages? etc.
I reference the travis.yml file in the FreeCAD source that builds in a 12.04 virtual machine. This isn't the definitive source. But probably should be. Does FreeCAD build on the oldest supported Ubuntu? https://travis-ci.org/sgrogan/FreeCAD
@drei, sorry for missing this before.
It should in FreeCAD 0.16, but post fc0.16 we will require c++11 support, which will kill 12.04 support, at least without upgrading and reconfiguring gcc. Which then kills the ability to make debug builds due to a third party lib, coin I think was the problem. I have done this to my system so I can no longer test default 12.04, But I can build and test any post 0.16 FreeCAD but only in a Release build.sgrogan wrote:Does FreeCAD build on the oldest supported Ubuntu?
Thanks jmaustpc,jmaustpc wrote: It should in FreeCAD 0.16, but post fc0.16 we will require c++11 support, which will kill 12.04 support, at least without upgrading and reconfiguring gcc. Which then kills the ability to make debug builds due to a third party lib, coin I think was the problem. I have done this to my system so I can no longer test default 12.04, But I can build and test any post 0.16 FreeCAD but only in a Release build.
The question was rhetorical, of course FreeCAD compiles presently. My idea was that the travis.yml file is more recent than the PPA control file. To Normandc's point libsoqt4 isn't required but some of it's dependencies are. I think drei's original question is the fundamental one. Of course there will be version issues with different distos, but a clear baseline would be benificial.
If this could be appended to drei's topic I think that would be great. He asked the true question and I'm sorry I missed it.
I had forgot I even asked that
Well, depending on how FreeCAD moves forward we will have to update the 3rd party dependencies. One important thing is post processing in FEM, because ickby is adding VTK support (which is really good) but opens up the question:
Is it time to modularize FreeCAD? Personally, I use everything related to mechanical engineering so I do need these dependencies, but other people have no need for it.
And also, perhaps we should start seeing what OS and distros we should support. As mentioned before 12.04 will cause conflicts, and there is also the problem with Ubuntu releases that are not LTS (no sure footing in which to add support).
Do you have a link to where it's discussed that a Debug build won't be possible in the future? AFAIK until now there are two C++11 related issues:It should in FreeCAD 0.16, but post fc0.16 we will require c++11 support, which will kill 12.04 support, at least without upgrading and reconfiguring gcc. Which then kills the ability to make debug builds due to a third party lib, coin I think was the problem. I have done this to my system so I can no longer test default 12.04, But I can build and test any post 0.16 FreeCAD but only in a Release build.
with boost and recently another issue appeared with vtk
Hi Werner, I will find it and get back to you, I was getting the compiling problem on my 12.04 machine with the updated GCC...so I can easily test again as well.wmayer wrote:Do you have a link to where it's discussed that a Debug build won't be possible in the future? AFAIK until now there are two C++11 related issues:It should in FreeCAD 0.16, but post fc0.16 we will require c++11 support, which will kill 12.04 support, at least without upgrading and reconfiguring gcc. Which then kills the ability to make debug builds due to a third party lib, coin I think was the problem. I have done this to my system so I can no longer test default 12.04, But I can build and test any post 0.16 FreeCAD but only in a Release build.
Jim
Hi Werner, I found itwmayer wrote:Do you have a link to where it's discussed that a Debug build won't be possible in the future? AFAIK until now there are two C++11 related issues:It should in FreeCAD 0.16, but post fc0.16 we will require c++11 support, which will kill 12.04 support, at least without upgrading and reconfiguring gcc. Which then kills the ability to make debug builds due to a third party lib, coin I think was the problem. I have done this to my system so I can no longer test default 12.04, But I can build and test any post 0.16 FreeCAD but only in a Release build.
viewtopic.php?f=10&t=14108&start=20#p113044
I just pulled master and check again a few minutes ago and confirmed that I still get the compile error. If you want me to test some changes I will be happy to do so.
Jim
