On gentoo linux the lastest stable ebuild is quite old and outdated: freecad-0.15.4671
Therefore I used to build 0.17 with freecad-9999.ebuild.
But that stopped linking a few months back and was not very useful at that point anyway.
For now I use 0.16 manually compiled.
But since 0.17 source code should be useable right now, please would someone who knows his stuff fix the freecad-9999.ebuild !?!
Much appreciated!
gentoo freecad-9999.ebuild fails
Re: gentoo freecad-9999.ebuild fails
Welcome to the forum!
Please provide any error messages and we'll hep you to fix it. I don't know if there is any other gentoo user around, but we definitely have working builds for fedora and ubuntu.
Is this the proper build script?
https://github.com/gentoo/gentoo/blob/m ... 999.ebuild?
"fight the good fight"
Thanks lads for having a look.
I attached a log file of my last try a few minutes ago. (--> build.log)
@sgrogan:
Yep, that's exactly the one I try to emerge and fails...
@sgrogan:
- build.log
- (709.96 KiB) Downloaded 172 times
You need the medc library in version 3.0.7 or later. In MED_Factory.cpp the compilation fails because med_bool is missing. It's defined as:
which you should find in med.h
typedef enum {MED_FALSE, MED_TRUE} med_bool ;
@wmayer: you're the man!
ah well, that was easy.
Replaced old sci-libs/med with sci-libs/libmed from the science-overlay ... and there she goes !
But wouldn't I be easier to put up a list of all requirements for *nix platforms (DISTRO independent!) ?
Then stupid people like me, who can't read log/code files that well, can simply look it up !?!
Anyways ... thanks a lot!
Excellent work people!
I think there is no doubt about thistreslah wrote:@wmayer: you're the man!
DISTRO independent is tough, the packages are named differently and the dependencies of dependencies pulled in is different. Looking at the .ebuild file I was going to post a list of missing dependencies but they seem to be there by default on gentoo.treslah wrote:But wouldn't I be easier to put up a list of all requirements for *nix platforms (DISTRO independent!) ?
The wiki always needs love. http://www.freecadweb.org/wiki/index.ph ... pileOnUnix
The gentoo section looks light. But I don't know a developer or active community member on this Distro. Your help with the wiki would be greatly appreciated! You can ask for an account by PM'ing a forum moderator.
Anyway glad it worked out so easily for you. I hadn't noticed your OP was your first post so a belated;
Welcome to FreeCAD and the Forum
Thanks for solving this. BTW, to anyone who might be fairly new to gentoo, you need to use layman to add the overlay (non gentoo project packages) "science" into portage to be able to install the aforementioned library.
In short:
last commands syncs overlays. emerge --sync doesn't do that. At least that is how I do it, but the Gentoo Wiki has more details, and maybe a better way https://wiki.gentoo.org/wiki/Overlay
The ideal, of course, would be for someone to maintain the freecad-9999 ebuild, and include the necessary libraries there.
In short:
# emerge layman
# layman -a science
# layman -S
