I think this is related to this: viewtopic.php?f=10&t=17947&start=10#p141487NormandC wrote:This is probably off-topic, but I just noticed tonight that when doing File --> Open after a fresh launch of the freecad-daily package, it always opens in the /usr/lib/freecad-daily folder. It's pretty damn annoying.
Python module numpy missing on clean PPA install.
Re: Python module numpy missing on clean PPA install.
"fight the good fight"
Correct, the Travis unit tests would definitely fail. For dependency references, it is best to look at the FreeCad brew formula that is also used by Travis as of late. In other words, Travis doesn't enumerate all the macOS dependencies because they are now encapsulate in the official FreeCAD homebrew formula.sgrogan wrote: Thanks, got it now, I had only looked at the travis.yaml. I'll look at the self tests. I thought all workbenches were loaded and this should have produced a failure on linux Travis.
That said, using brew deps --tree FreeCAD we can see that python-numpy is a transitive dependency pulled in by matplotlib hence we don't need specify it directly - in case you noticed that in the FreeCAD formula that I cited above ...
I don't think the FreeCAD self tests check dependencies directly. But I thought all workbenches were at least activated by the self tests. I would think if Path wouldn't load the test should fail.blacey wrote:For dependency references, it is best to look at the FreeCad brew formula
On Travis python-matplotlib is a dependency so python-numpy gets pulled in.
On the PPA python-matplotlib is a Suggests. I need to research the implications of this.
Thanks blacey, this is the lead I needed.
Great Screenshot!blacey wrote:Screen Shot 2016-10-26 at 5.07.45 PM.jpg (111.69 KiB) Viewed 17 times
python-matpotlib depends on python3? OK maybe matpotlib has python2/3 compliant code.
python-numpy depends on python3 and gcc? A python3 dependency and a VS C/C++ dependency would break windows. gcc is more forgiving.
Thanks, I'll post in there but I'll do further testing first. I'm wondering if sharing the same .FreeCAD folder between 0.16 and 0.17 is creating the problem...sgrogan wrote:I think this is related to this: viewtopic.php?f=10&t=17947&start=10#p141487NormandC wrote:File --> Open after a fresh launch of the freecad-daily package, it always opens in the /usr/lib/freecad-daily folder. It's pretty damn annoying.
