Python module numpy missing on clean PPA install.
I installed a pristine Ubuntu vm (16.04.1 LTS) and immediately added freecad-daily PPA to it and installed it.
The moment I try to select the Path workbench I get a popup saying "No module named numpy" (all other WBs seem OK). Is this a known issue?
Other than that it works like a charm! Great work guys
Re: Python module numpy missing on clean PPA install.
Thanks mlabert! It seems FreeCAD has a hard runtime dependency, not addressed, to python-numpy now. Can you try the FEM WB in the same experiment? We need a doc update.
should fix it.
EDIT: @chrisb, what's the situation on OSX?
sudo apt-get install python-numpy
"fight the good fight"
I did start the FEM WB and it was good - is there anything I should run in the WB ?
I can select Path WB and FEM WB without problems. Tiny test in PathWB worked, no idea how or what to test in FEM WB.
OS: Mac OS X
Version: 0.17.8443 (Git)
OCC version: 7.0.0
OS: Mac OS X
OCC version: 7.0.0
mlampert wrote:I did start the FEM WB and it was good - is there anything I should run in the WB ?
I'm not sure how to test I did discern thischrisb wrote:I can select Path WB and FEM WB without problems. Tiny test in PathWB worked, no idea how or what to test in FEM WB.
C:\Users\Chris\GitHub\FreeCAD\src\Mod\Arch\Dice3DS\dom3ds.py (1 hit)
Line 21: import numpy
C:\Users\Chris\GitHub\FreeCAD\src\Mod\Arch\Dice3DS\util.py (1 hit)
Line 9: import numpy
C:\Users\Chris\GitHub\FreeCAD\src\Mod\Fem\ccxFrdReader.py (1 hit)
Line 29: import numpy as np
C:\Users\Chris\GitHub\FreeCAD\src\Mod\Fem\_TaskPanelShowResult.py (1 hit)
Line 30: import numpy as np
C:\Users\Chris\GitHub\FreeCAD\src\Mod\PartDesign\WizardShaft\SegmentFunction.py (1 hit)
Line 24: import numpy as np
C:\Users\Chris\GitHub\FreeCAD\src\Mod\PartDesign\WizardShaft\Shaft.py (1 hit)
Line 288: import numpy as np
C:\Users\Chris\GitHub\FreeCAD\src\Mod\Path\PathScripts\PathProfile.py (1 hit)
Line 27: import numpy
Slightly off topic. Can someone explain the OSX/Python environment. I don't see this dependency in Travis.
I am not familiar with the python situation on OSX but numpy seems to be shipped with FreeCAD.
I can do the following in FreeCAD's python console and the result shows the shipped path:
import numpy
>>> numpy.__path__
['/Users/cb/freeCAD/FreeCADDaily.app/Contents/lib/python2.7/site-packages/numpy']
Thanks again chrisb! I think we need bblacey to explain, at least to mechrisb wrote:I can do the following in FreeCAD's python console and the result shows the shipped path:
Hello sgrogan,
OS: Ubuntu 14.04.5 LTS
Version: 0.17.8775 (Git)
Build type: None
Hash: 761d684c79afe4a5758e782bc4c4fb88864701a5
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
This is probably off-topic, but I just noticed tonight that when doing File --> Open after a fresh launch of the freecad-daily package, it always opens in the /usr/lib/freecad-daily folder. It's pretty damn annoying.sgrogan wrote:I'll add python-numpy as a runtime dependency for the PPA, unless there are objections?
Build type: None
Qt version: 4.8.6
FreeCAD on macOS / OS X is installed with the following dependencies, including python-numpy.sgrogan wrote:Thanks again chrisb! I think we need bblacey to explain, at least to mechrisb wrote:I can do the following in FreeCAD's python console and the result shows the shipped path:
[blacey@mbp ~]$ brew deps --include-build freecad
FreeCAD/freecad/coin
FreeCAD/freecad/med-file
FreeCAD/freecad/nglib
FreeCAD/freecad/pivy
FreeCAD/freecad/pyside
FreeCAD/freecad/pyside-tools
FreeCAD/freecad/shiboken
autoconf
automake
boost
boost-python
ccache
cmake
cppunit
eigen
fontconfig
freeimage
freetype
gcc
gdbm
git
gl2ps
hdf5
homebrew/python/matplotlib
homebrew/python/numpy
homebrew/science/hdf5
homebrew/science/opencascade
homebrew/science/orocos-kdl
homebrew/science/vtk
jpeg
libpng
libtiff
libtool
makedepend
opencascade
openssl
pcre
pkg-config
python
qt
readline
sphinx-doc
sqlite
swig
szip
tbb
xerces-c
Thanks, got it now, I had only looked at the travis.yaml. I'll look at the self tests. I thought all workbenches were loaded and this should have produced a failure on linux Travis.blacey wrote:FreeCAD on macOS / OS X is installed with the following dependencies, including python-numpy.
