sgrogan wrote:Thanks! And your first post! Welcome to FreeCAD and the forum
Packages look correct. Can you also post the cmake logs, I don't see an obvious problem. I'm compiling on Kubuntu 14.4 without issue (not yet today though)
Do you have either the FreeCAD stable or daily PPA installed?
I just followed instructions, without any deviations:
git clone https://github.com/FreeCAD/FreeCAD.git free-cad-code
Here are CMakeOutput.log and CMakeError.log:
The system is: Linux - 3.13.0-24-generic - x86_64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Compiler: /usr/bin/cc
Build flags:
Id flags:
The output was:
0
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "a.out"
The C compiler identification is GNU, found in "/home/osman/freecad/CMakeFiles/2.8.12.2/CompilerIdC/a.out"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Compiler: /usr/bin/c++
Build flags:
Id flags:
The output was:
0
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "a.out"
The CXX compiler identification is GNU, found in "/home/osman/freecad/CMakeFiles/2.8.12.2/CompilerIdCXX/a.out"
Determining if the C compiler works passed with the following output:
Change Dir: /home/osman/freecad/CMakeFiles/CMakeTmp
Run Build Command:/usr/bin/make "cmTryCompileExec3379732549/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec3379732549.dir/build.make CMakeFiles/cmTryCompileExec3379732549.dir/build
make[1]: Entering directory `/home/osman/freecad/CMakeFiles/CMakeTmp'
/usr/bin/cmake -E cmake_progress_report /home/osman/freecad/CMakeFiles/CMakeTmp/CMakeFiles 1
Building C object CMakeFiles/cmTryCompileExec3379732549.dir/testCCompiler.c.o
/usr/bin/cc -o CMakeFiles/cmTryCompileExec3379732549.dir/testCCompiler.c.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/testCCompiler.c
Linking C executable cmTryCompileExec3379732549
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3379732549.dir/link.txt --verbose=1
/usr/bin/cc CMakeFiles/cmTryCompileExec3379732549.dir/testCCompiler.c.o -o cmTryCompileExec3379732549 -rdynamic
make[1]: Leaving directory `/home/osman/freecad/CMakeFiles/CMakeTmp'
Detecting C compiler ABI info compiled with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec3029801809/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec3029801809.dir/build.make CMakeFiles/cmTryCompileExec3029801809.dir/build
Building C object CMakeFiles/cmTryCompileExec3029801809.dir/CMakeCCompilerABI.c.o
/usr/bin/cc -o CMakeFiles/cmTryCompileExec3029801809.dir/CMakeCCompilerABI.c.o -c /usr/share/cmake-2.8/Modules/CMakeCCompilerABI.c
Linking C executable cmTryCompileExec3029801809
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3029801809.dir/link.txt --verbose=1
/usr/bin/cc -v CMakeFiles/cmTryCompileExec3029801809.dir/CMakeCCompilerABI.c.o -o cmTryCompileExec3029801809 -rdynamic
Using built-in specs.
COLLECT_GCC=/usr/bin/cc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.8/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.8.4-2ubuntu1~14.04.3' --with-bugurl=file:///usr/share/doc/gcc-4.8/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.8 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.8 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libmudflap --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.8-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.3)
COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.8/:/usr/lib/gcc/x86_64-linux-gnu/4.8/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.8/:/usr/lib/gcc/x86_64-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.8/:/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../:/lib/:/usr/lib/
COLLECT_GCC_OPTIONS='-v' '-o' 'cmTryCompileExec3029801809' '-rdynamic' '-mtune=generic' '-march=x86-64'
/usr/lib/gcc/x86_64-linux-gnu/4.8/collect2 --sysroot=/ --build-id --eh-frame-hdr -m elf_x86_64 --hash-style=gnu --as-needed -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -z relro -o cmTryCompileExec3029801809 /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crt1.o /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.8/crtbegin.o -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../.. CMakeFiles/cmTryCompileExec3029801809.dir/CMakeCCompilerABI.c.o -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/x86_64-linux-gnu/4.8/crtend.o /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crtn.o
Parsed C implicit link information from above output:
link line regex: [^( *|.*[/\])(ld|([^/\]+-)?ld|collect2)[^/\]*( |$)]
ignore line: [Change Dir: /home/osman/freecad/CMakeFiles/CMakeTmp]
ignore line: []
ignore line: [Run Build Command:/usr/bin/make "cmTryCompileExec3029801809/fast"]
ignore line: [/usr/bin/make -f CMakeFiles/cmTryCompileExec3029801809.dir/build.make CMakeFiles/cmTryCompileExec3029801809.dir/build]
ignore line: [make[1]: Entering directory `/home/osman/freecad/CMakeFiles/CMakeTmp']
ignore line: [/usr/bin/cmake -E cmake_progress_report /home/osman/freecad/CMakeFiles/CMakeTmp/CMakeFiles 1]
ignore line: [Building C object CMakeFiles/cmTryCompileExec3029801809.dir/CMakeCCompilerABI.c.o]
ignore line: [/usr/bin/cc -o CMakeFiles/cmTryCompileExec3029801809.dir/CMakeCCompilerABI.c.o -c /usr/share/cmake-2.8/Modules/CMakeCCompilerABI.c]
ignore line: [Linking C executable cmTryCompileExec3029801809]
ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3029801809.dir/link.txt --verbose=1]
ignore line: [/usr/bin/cc -v CMakeFiles/cmTryCompileExec3029801809.dir/CMakeCCompilerABI.c.o -o cmTryCompileExec3029801809 -rdynamic ]
ignore line: [Using built-in specs.]
ignore line: [COLLECT_GCC=/usr/bin/cc]
ignore line: [COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.8/lto-wrapper]
ignore line: [Target: x86_64-linux-gnu]
ignore line: [Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.8.4-2ubuntu1~14.04.3' --with-bugurl=file:///usr/share/doc/gcc-4.8/README.Bugs --enable-languages=c,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.8 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.8 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --disable-libmudflap --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-4.8-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-4.8-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu]
ignore line: [Thread model: posix]
ignore line: [gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.3) ]
ignore line: [COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.8/:/usr/lib/gcc/x86_64-linux-gnu/4.8/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.8/:/usr/lib/gcc/x86_64-linux-gnu/]
ignore line: [LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/4.8/:/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../:/lib/:/usr/lib/]
ignore line: [COLLECT_GCC_OPTIONS='-v' '-o' 'cmTryCompileExec3029801809' '-rdynamic' '-mtune=generic' '-march=x86-64']
link line: [ /usr/lib/gcc/x86_64-linux-gnu/4.8/collect2 --sysroot=/ --build-id --eh-frame-hdr -m elf_x86_64 --hash-style=gnu --as-needed -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -z relro -o cmTryCompileExec3029801809 /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crt1.o /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.8/crtbegin.o -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../.. CMakeFiles/cmTryCompileExec3029801809.dir/CMakeCCompilerABI.c.o -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/x86_64-linux-gnu/4.8/crtend.o /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crtn.o]
arg [/usr/lib/gcc/x86_64-linux-gnu/4.8/collect2] ==> ignore
arg [--sysroot=/] ==> ignore
arg [--build-id] ==> ignore
arg [--eh-frame-hdr] ==> ignore
arg [-m] ==> ignore
arg [elf_x86_64] ==> ignore
arg [--hash-style=gnu] ==> ignore
arg [--as-needed] ==> ignore
arg [-export-dynamic] ==> ignore
arg [-dynamic-linker] ==> ignore
arg [/lib64/ld-linux-x86-64.so.2] ==> ignore
arg [-zrelro] ==> ignore
arg [-o] ==> ignore
arg [cmTryCompileExec3029801809] ==> ignore
arg [/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crt1.o] ==> ignore
arg [/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crti.o] ==> ignore
arg [/usr/lib/gcc/x86_64-linux-gnu/4.8/crtbegin.o] ==> ignore
arg [-L/usr/lib/gcc/x86_64-linux-gnu/4.8] ==> dir [/usr/lib/gcc/x86_64-linux-gnu/4.8]
arg [-L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu] ==> dir [/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu]
arg [-L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../../lib] ==> dir [/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../../lib]
arg [-L/lib/x86_64-linux-gnu] ==> dir [/lib/x86_64-linux-gnu]
arg [-L/lib/../lib] ==> dir [/lib/../lib]
arg [-L/usr/lib/x86_64-linux-gnu] ==> dir [/usr/lib/x86_64-linux-gnu]
arg [-L/usr/lib/../lib] ==> dir [/usr/lib/../lib]
arg [-L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../..] ==> dir [/usr/lib/gcc/x86_64-linux-gnu/4.8/../../..]
arg [CMakeFiles/cmTryCompileExec3029801809.dir/CMakeCCompilerABI.c.o] ==> ignore
arg [-lgcc] ==> lib [gcc]
arg [-lgcc_s] ==> lib [gcc_s]
arg [--no-as-needed] ==> ignore
arg [-lc] ==> lib [c]
arg [/usr/lib/gcc/x86_64-linux-gnu/4.8/crtend.o] ==> ignore
arg [/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crtn.o] ==> ignore
remove lib [gcc]
remove lib [gcc_s]
remove lib [gcc]
remove lib [gcc_s]
collapse library dir [/usr/lib/gcc/x86_64-linux-gnu/4.8] ==> [/usr/lib/gcc/x86_64-linux-gnu/4.8]
collapse library dir [/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu] ==> [/usr/lib/x86_64-linux-gnu]
collapse library dir [/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../../lib] ==> [/usr/lib]
collapse library dir [/lib/x86_64-linux-gnu] ==> [/lib/x86_64-linux-gnu]
collapse library dir [/lib/../lib] ==> [/lib]
collapse library dir [/usr/lib/x86_64-linux-gnu] ==> [/usr/lib/x86_64-linux-gnu]
collapse library dir [/usr/lib/../lib] ==> [/usr/lib]
collapse library dir [/usr/lib/gcc/x86_64-linux-gnu/4.8/../../..] ==> [/usr/lib]
implicit libs: [c]
implicit dirs: [/usr/lib/gcc/x86_64-linux-gnu/4.8;/usr/lib/x86_64-linux-gnu;/usr/lib;/lib/x86_64-linux-gnu;/lib]
implicit fwks: []
Determining if the CXX compiler works passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec3429967836/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec3429967836.dir/build.make CMakeFiles/cmTryCompileExec3429967836.dir/build
Building CXX object CMakeFiles/cmTryCompileExec3429967836.dir/testCXXCompiler.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec3429967836.dir/testCXXCompiler.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
Linking CXX executable cmTryCompileExec3429967836
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3429967836.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTryCompileExec3429967836.dir/testCXXCompiler.cxx.o -o cmTryCompileExec3429967836 -rdynamic
Detecting CXX compiler ABI info compiled with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec1385295130/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec1385295130.dir/build.make CMakeFiles/cmTryCompileExec1385295130.dir/build
Building CXX object CMakeFiles/cmTryCompileExec1385295130.dir/CMakeCXXCompilerABI.cpp.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec1385295130.dir/CMakeCXXCompilerABI.cpp.o -c /usr/share/cmake-2.8/Modules/CMakeCXXCompilerABI.cpp
Linking CXX executable cmTryCompileExec1385295130
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec1385295130.dir/link.txt --verbose=1
/usr/bin/c++ -v CMakeFiles/cmTryCompileExec1385295130.dir/CMakeCXXCompilerABI.cpp.o -o cmTryCompileExec1385295130 -rdynamic
COLLECT_GCC=/usr/bin/c++
Thread model: posix
COLLECT_GCC_OPTIONS='-v' '-o' 'cmTryCompileExec1385295130' '-rdynamic' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
/usr/lib/gcc/x86_64-linux-gnu/4.8/collect2 --sysroot=/ --build-id --eh-frame-hdr -m elf_x86_64 --hash-style=gnu --as-needed -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -z relro -o cmTryCompileExec1385295130 /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crt1.o /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.8/crtbegin.o -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../.. CMakeFiles/cmTryCompileExec1385295130.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-linux-gnu/4.8/crtend.o /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crtn.o
Parsed CXX implicit link information from above output:
ignore line: []
ignore line: [Run Build Command:/usr/bin/make "cmTryCompileExec1385295130/fast"]
ignore line: [/usr/bin/make -f CMakeFiles/cmTryCompileExec1385295130.dir/build.make CMakeFiles/cmTryCompileExec1385295130.dir/build]
ignore line: [Building CXX object CMakeFiles/cmTryCompileExec1385295130.dir/CMakeCXXCompilerABI.cpp.o]
ignore line: [/usr/bin/c++ -o CMakeFiles/cmTryCompileExec1385295130.dir/CMakeCXXCompilerABI.cpp.o -c /usr/share/cmake-2.8/Modules/CMakeCXXCompilerABI.cpp]
ignore line: [Linking CXX executable cmTryCompileExec1385295130]
ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec1385295130.dir/link.txt --verbose=1]
ignore line: [/usr/bin/c++ -v CMakeFiles/cmTryCompileExec1385295130.dir/CMakeCXXCompilerABI.cpp.o -o cmTryCompileExec1385295130 -rdynamic ]
ignore line: [COLLECT_GCC=/usr/bin/c++]
ignore line: [COLLECT_GCC_OPTIONS='-v' '-o' 'cmTryCompileExec1385295130' '-rdynamic' '-shared-libgcc' '-mtune=generic' '-march=x86-64']
link line: [ /usr/lib/gcc/x86_64-linux-gnu/4.8/collect2 --sysroot=/ --build-id --eh-frame-hdr -m elf_x86_64 --hash-style=gnu --as-needed -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -z relro -o cmTryCompileExec1385295130 /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crt1.o /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.8/crtbegin.o -L/usr/lib/gcc/x86_64-linux-gnu/4.8 -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.8/../../.. CMakeFiles/cmTryCompileExec1385295130.dir/CMakeCXXCompilerABI.cpp.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-linux-gnu/4.8/crtend.o /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crtn.o]
arg [-m] ==> ignore
arg [-o] ==> ignore
arg [cmTryCompileExec1385295130] ==> ignore
arg [CMakeFiles/cmTryCompileExec1385295130.dir/CMakeCXXCompilerABI.cpp.o] ==> ignore
arg [-lstdc++] ==> lib [stdc++]
arg [-lm] ==> lib [m]
remove lib [gcc_s]
remove lib [gcc]
remove lib [gcc_s]
remove lib [gcc]
implicit libs: [stdc++;m;c]
implicit fwks: []
Determining if the include file GL/gl.h exists passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec2172540259/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec2172540259.dir/build.make CMakeFiles/cmTryCompileExec2172540259.dir/build
Building C object CMakeFiles/cmTryCompileExec2172540259.dir/CheckIncludeFile.c.o
/usr/bin/cc -o CMakeFiles/cmTryCompileExec2172540259.dir/CheckIncludeFile.c.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckIncludeFile.c
Linking C executable cmTryCompileExec2172540259
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec2172540259.dir/link.txt --verbose=1
/usr/bin/cc CMakeFiles/cmTryCompileExec2172540259.dir/CheckIncludeFile.c.o -o cmTryCompileExec2172540259 -rdynamic
Determining if the include file istream exists passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec4034390393/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec4034390393.dir/build.make CMakeFiles/cmTryCompileExec4034390393.dir/build
Building CXX object CMakeFiles/cmTryCompileExec4034390393.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec4034390393.dir/CheckIncludeFile.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTryCompileExec4034390393
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec4034390393.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTryCompileExec4034390393.dir/CheckIncludeFile.cxx.o -o cmTryCompileExec4034390393 -rdynamic
Determining if the include file ostream exists passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec2294348505/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec2294348505.dir/build.make CMakeFiles/cmTryCompileExec2294348505.dir/build
Building CXX object CMakeFiles/cmTryCompileExec2294348505.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec2294348505.dir/CheckIncludeFile.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTryCompileExec2294348505
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec2294348505.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTryCompileExec2294348505.dir/CheckIncludeFile.cxx.o -o cmTryCompileExec2294348505 -rdynamic
Determining if the include file fstream exists passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec2433300197/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec2433300197.dir/build.make CMakeFiles/cmTryCompileExec2433300197.dir/build
Building CXX object CMakeFiles/cmTryCompileExec2433300197.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec2433300197.dir/CheckIncludeFile.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTryCompileExec2433300197
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec2433300197.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTryCompileExec2433300197.dir/CheckIncludeFile.cxx.o -o cmTryCompileExec2433300197 -rdynamic
Determining if the include file sstream exists passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec4183015543/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec4183015543.dir/build.make CMakeFiles/cmTryCompileExec4183015543.dir/build
Building CXX object CMakeFiles/cmTryCompileExec4183015543.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec4183015543.dir/CheckIncludeFile.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTryCompileExec4183015543
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec4183015543.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTryCompileExec4183015543.dir/CheckIncludeFile.cxx.o -o cmTryCompileExec4183015543 -rdynamic
Determining if the include file ios exists passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec288461732/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec288461732.dir/build.make CMakeFiles/cmTryCompileExec288461732.dir/build
Building CXX object CMakeFiles/cmTryCompileExec288461732.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec288461732.dir/CheckIncludeFile.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTryCompileExec288461732
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec288461732.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTryCompileExec288461732.dir/CheckIncludeFile.cxx.o -o cmTryCompileExec288461732 -rdynamic
Determining if the include file iostream exists passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec634123986/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec634123986.dir/build.make CMakeFiles/cmTryCompileExec634123986.dir/build
Building CXX object CMakeFiles/cmTryCompileExec634123986.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec634123986.dir/CheckIncludeFile.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTryCompileExec634123986
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec634123986.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTryCompileExec634123986.dir/CheckIncludeFile.cxx.o -o cmTryCompileExec634123986 -rdynamic
Determining if the include file iomanip exists passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec3036650179/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec3036650179.dir/build.make CMakeFiles/cmTryCompileExec3036650179.dir/build
Building CXX object CMakeFiles/cmTryCompileExec3036650179.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec3036650179.dir/CheckIncludeFile.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTryCompileExec3036650179
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3036650179.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTryCompileExec3036650179.dir/CheckIncludeFile.cxx.o -o cmTryCompileExec3036650179 -rdynamic
Run Build Command:/usr/bin/make "cmTryCompileExec3733444018/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec3733444018.dir/build.make CMakeFiles/cmTryCompileExec3733444018.dir/build
Building CXX object CMakeFiles/cmTryCompileExec3733444018.dir/CheckIncludeFile.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec3733444018.dir/CheckIncludeFile.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTryCompileExec3733444018
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3733444018.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTryCompileExec3733444018.dir/CheckIncludeFile.cxx.o -o cmTryCompileExec3733444018 -rdynamic
Determining if the CXX compiler has std namespace passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec143931371/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec143931371.dir/build.make CMakeFiles/cmTryCompileExec143931371.dir/build
Building CXX object CMakeFiles/cmTryCompileExec143931371.dir/TestForSTDNamespace.cxx.o
/usr/bin/c++ -o CMakeFiles/cmTryCompileExec143931371.dir/TestForSTDNamespace.cxx.o -c /usr/share/cmake-2.8/Modules/TestForSTDNamespace.cxx
Linking CXX executable cmTryCompileExec143931371
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec143931371.dir/link.txt --verbose=1
/usr/bin/c++ CMakeFiles/cmTryCompileExec143931371.dir/TestForSTDNamespace.cxx.o -o cmTryCompileExec143931371 -rdynamic
Determining if the Q_WS_X11 exist passed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec2418914321/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec2418914321.dir/build.make CMakeFiles/cmTryCompileExec2418914321.dir/build
Building CXX object CMakeFiles/cmTryCompileExec2418914321.dir/CheckSymbolExists.cxx.o
/usr/bin/c++ -fdump-tree-original-raw -Wall -Wextra -Wno-write-strings -std=c++11 -I/usr/include/qt4 -o CMakeFiles/cmTryCompileExec2418914321.dir/CheckSymbolExists.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx
Linking CXX executable cmTryCompileExec2418914321
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec2418914321.dir/link.txt --verbose=1
/usr/bin/c++ -fdump-tree-original-raw -Wall -Wextra -Wno-write-strings -std=c++11 CMakeFiles/cmTryCompileExec2418914321.dir/CheckSymbolExists.cxx.o -o cmTryCompileExec2418914321 -rdynamic
File /home/osman/freecad/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:
#include <QtCore/qglobal.h>
int main(int argc, char** argv)
(void)argv;
#ifndef Q_WS_X11
return ((int*)(&Q_WS_X11))[argc];
#else
(void)argc;
return 0;
#endif
Determining if the Q_WS_WIN exist failed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec1921779244/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec1921779244.dir/build.make CMakeFiles/cmTryCompileExec1921779244.dir/build
Building CXX object CMakeFiles/cmTryCompileExec1921779244.dir/CheckSymbolExists.cxx.o
/usr/bin/c++ -fdump-tree-original-raw -Wall -Wextra -Wno-write-strings -std=c++11 -I/usr/include/qt4 -o CMakeFiles/cmTryCompileExec1921779244.dir/CheckSymbolExists.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx
/home/osman/freecad/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx: In function ‘int main(int, char**)’:
/home/osman/freecad/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:8:19: error: ‘Q_WS_WIN’ was not declared in this scope
return ((int*)(&Q_WS_WIN))[argc];
make[1]: *** [CMakeFiles/cmTryCompileExec1921779244.dir/CheckSymbolExists.cxx.o] Error 1
make: *** [cmTryCompileExec1921779244/fast] Error 2
(void)argv;
#ifndef Q_WS_WIN
#else
(void)argc;
return 0;
#endif
Determining if the Q_WS_QWS exist failed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec688762081/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec688762081.dir/build.make CMakeFiles/cmTryCompileExec688762081.dir/build
Building CXX object CMakeFiles/cmTryCompileExec688762081.dir/CheckSymbolExists.cxx.o
/usr/bin/c++ -fdump-tree-original-raw -Wall -Wextra -Wno-write-strings -std=c++11 -I/usr/include/qt4 -o CMakeFiles/cmTryCompileExec688762081.dir/CheckSymbolExists.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx
/home/osman/freecad/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:8:19: error: ‘Q_WS_QWS’ was not declared in this scope
return ((int*)(&Q_WS_QWS))[argc];
make[1]: *** [CMakeFiles/cmTryCompileExec688762081.dir/CheckSymbolExists.cxx.o] Error 1
make: *** [cmTryCompileExec688762081/fast] Error 2
(void)argv;
#ifndef Q_WS_QWS
#else
(void)argc;
return 0;
#endif
Determining if the Q_WS_MAC exist failed with the following output:
Run Build Command:/usr/bin/make "cmTryCompileExec2697941714/fast"
/usr/bin/make -f CMakeFiles/cmTryCompileExec2697941714.dir/build.make CMakeFiles/cmTryCompileExec2697941714.dir/build
Building CXX object CMakeFiles/cmTryCompileExec2697941714.dir/CheckSymbolExists.cxx.o
/usr/bin/c++ -fdump-tree-original-raw -Wall -Wextra -Wno-write-strings -std=c++11 -I/usr/include/qt4 -o CMakeFiles/cmTryCompileExec2697941714.dir/CheckSymbolExists.cxx.o -c /home/osman/freecad/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx
/home/osman/freecad/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:8:19: error: ‘Q_WS_MAC’ was not declared in this scope
return ((int*)(&Q_WS_MAC))[argc];
make[1]: *** [CMakeFiles/cmTryCompileExec2697941714.dir/CheckSymbolExists.cxx.o] Error 1
make: *** [cmTryCompileExec2697941714/fast] Error 2
(void)argv;
#ifndef Q_WS_MAC
#else
(void)argc;
return 0;
#endif
